Author Topic: Meng and Roden Fokker DR1: Jasta 4, Jasta 6, and Jasta 11  (Read 150822 times)
« Reply #315 on: December 15, 2020, 12:16:22 AM »
You make it all sound so easy Rick...
Quote
...So I stripped all of the paint, re sprayed a beige-ish grey CDL base...
How do you strip the paint without damaging your work?
Please bear in mind I'm a rookie
I used a soft cloth with Brake Fluid and carefully rubbed the surfaces. The oils came off easily and the acrylic base only took about 30 minutes. . Then I use dish detergent to wash off the oily residue. I sprayed about an hour later then did the streaking later in the afternoon. When things go well the streaking only takes about 5 minutes per surface  ::)
« Last Edit: December 15, 2020, 12:28:24 AM by RAGIII »
« Reply #316 on: December 15, 2020, 08:06:22 AM »
« Reply #317 on: December 17, 2020, 11:20:52 PM »
Nice colours on the streaking, Rick! I do think this method has great possibilities.... Regards, Marc.
« Reply #318 on: December 18, 2020, 12:09:59 AM »
Thanks for looking in and commenting Terri and Marc!
« Reply #319 on: December 18, 2020, 04:10:07 AM »
Rick on speed! Your Triplane show here is unbelievable!
Willem, I have made also good experience with normal alcohol (in german "Spiritus", a cheap undrinkable alcohol for cleaning) for acrylic paints, e.g. Gunze Hxxx, Tamiya or Mr. Paint. Even with oil stripes on top the alcohol goes a bit trough are solves the paint below.
If I so not rub to strong with cotton tab my Alclad Primer survives such attack.
I suggest to use a cheap model kit for testing paints, airbrush, brushes and ... cleaning ;)
« Reply #320 on: December 18, 2020, 09:24:09 AM »
So I have progressed on both kits. I painted the rear fuselage and Horizontal tail white prior to masking and painting the black. I also have painted the red band and ellow X on the Roden fuselage. I will touch it up after painting the red tail stripes.
« Reply #321 on: December 18, 2020, 11:17:27 AM »
Wow!! Great jump ahead in progress
Offline acewwi
« Reply #322 on: December 18, 2020, 09:54:40 PM »
I love yours painting Rick
Spyros
« Reply #323 on: December 18, 2020, 10:46:13 PM »
Those colors really set this one off, Rick!
« Reply #324 on: December 19, 2020, 09:19:48 AM »
Thanks Steve!
Spyros
Thanks. I do like painting so greatly appreciated!
Thanks Ken. I also like the color contrast!
So moving along on the Meng kit. I have masked and painted the black stripes on the fuselage. I am pleased that there is only a Small amount of adjustment and touch up needed  8)
Offline Radarman
« Reply #325 on: December 19, 2020, 10:16:09 AM »
RAG III,
These two are looking great. I must say, I'm glad to see you continuing with these builds.
        Kevin
« Reply #326 on: December 19, 2020, 11:35:50 AM »
RAG III,
        Kevin
Thanks for the comment Kevin!
Offline Fvdm
« Reply #327 on: December 19, 2020, 04:44:53 PM »
I really like the different color schemes.  Back then they were more creative in painting than nowadays.  I see what you mean when you say a little touch up is needed but I think it is a nice little worn look. It doesn't disturb me at all. Keep up the good work.
Ferry
« Last Edit: December 19, 2020, 05:42:01 PM by Fvdm »
« Reply #328 on: December 19, 2020, 05:28:27 PM »
I'm with Fvdm. Touch up if you want to, but the lack of absolute perfection makes it look more real in my eyes.
Great work over all!
« Reply #329 on: December 19, 2020, 10:08:59 PM »
You have done it again Rick!
Simply amazing!
