Author Topic: WNW Pup Night Trainer/Stars & Moon  (Read 12757 times)
Re: WNW Pup Night Trainer/Stars & Moon
« Reply #15 on: December 14, 2012, 01:53:50 AM »
Truly lovely, Bob!  Those stars must have been challenging to apply.  Can you imagine what the poor bloke who painted them on the original went through, expecially on the top wing?
Offline Jim52
« Reply #16 on: December 14, 2012, 02:10:53 AM »
I would guess that they took the wings off to do all those stars.
Jim
« Reply #17 on: December 14, 2012, 02:54:36 AM »
Thanks guys.  Although the Pheon instruction booklet is well detailed, it does not offer any informantion regarding how the stars were applied to the prototype.  I think Rowan had only a couple of photos of each aircraft to work from.
As for application to the model, the Pheon stars are indeed individual decals.  The color plan provided by Pheon is very helpful, although there is no guide for most of the bottom wing (except the portion not covered by the top wing) or the right side of the fuselage, which you are left to interpret, I suspect because the photos of the real thing do not show those surfaces.  Interestingly, the portion of the bottom wings shown in the color plan seem to suggest a greater density of stars on the lower wings than on the upper wing.  0:)
Although it seems like a big job, I found application of the individual stars to be quite relaxing and fun, as the surface came to life.  The secret was to not try to do too much at a single sitting.  I did the top wing in two sessions, then two more sessions for the bottom, and two sessions for the fuselage, with another for the tail surfaces.  These were probably 15-20 minute sessions, tops.  I would cut out about 4-6 stars in a strip, soak per instructions, and set with a small brush in a little MicroSol.  Once positioned where I wanted them, I then hit them with a warm hairdryer to snuggle them down.  Then back to the bench for another 4-6 stars, and repeat until I had whatever section I was working on finished.  A little tedious at times, but very rewarding!
Now . . . on to rigging the tail and struts, then adding the top wing before main rigging!
« Reply #18 on: December 14, 2012, 04:12:53 AM »
  Bob,
Thanks for the tip concerning the stars.Once I return to modeling I think I'll just have to order these excellent decals from Rowan for one of my Pups too. Again outstanding work my old friend. I hope they're not as tedious as applying ribtapes.
« Reply #19 on: December 14, 2012, 05:44:25 AM »
Thanks Gregory!  I found the stars much easier than ribtapes to work with.  The small roundish shape is easier to maneuver off of the backing and on the surface.
Offline Dal Gavan
« Reply #20 on: December 14, 2012, 08:27:17 AM »
That's looking brilliant, Bob.  It's a great scheme, and a good reason to get another Pup.  Eventually.
Dal.
« Reply #21 on: December 15, 2012, 06:58:57 AM »
It is really taking shape.  I love the scheme and may have to do this one as well, it would make a great companion to my Candy Stripe version.  It is certainly a striking scheme.
« Reply #22 on: December 15, 2012, 08:53:42 AM »
Thanks guys.  I agree: Rowan's Pup Pets & Trainers sheet is really outstanding, with several very neat schemes.  I really love the Candy Striper you did Mark, and would like to do that one, but I also like McCudden's night fighter too.  Actually, I like them all!  ;D  So many Pups, so little time.  ;)
« Reply #23 on: December 15, 2012, 02:37:38 PM »
thats a really great scheme. i will have to check into rowans sheet for the trainers.
« Reply #24 on: December 17, 2012, 10:10:32 AM »
More progress, slow but steady, and the end is in sight.  Here is the rigged tail:
. . . and a 3/4 shot.  I am setting up the rigging.
A closeup of the fuselage man-in-the-moon emblem:
« Reply #25 on: December 17, 2012, 10:21:11 AM »
. . . oooops!  Hit the post button by mistake.  Here are some more photos and a top wing teaser:
I still have details to add, including the night lights and Holt flares.  I forgot to photograph them, but they'll show up in the next round of photos.  I hope to have the rigging completed by the end of the week, then she'll be in the home stretch!
I'll solicit help while I have a chance.  The aileron control cables are a short run from the horn to the wing.  It would be difficult to rig with monofilament, because of the short run and because the cable goes directly into the wing without a buckle eyelet.  Something stiff but bendalble would be ideal.  Any suggestions?
« Reply #26 on: December 17, 2012, 10:32:06 AM »
    Bob,
Excellent update as alway my friend.Would E-Z Line fit your purpose for the rigging you wrote of?
Highets Regards,
« Reply #27 on: December 17, 2012, 12:44:27 PM »
This is shaping up very nicely! A piece of fine spring wire might do it.
« Reply #28 on: December 17, 2012, 02:54:21 PM »
Thanks guys!  I found an effective solution tonight to the aileron control wire, while taking my wife shopping at the local Michael's Craft Store (a double win!).  I found a spool of 32 guage beading wire, very fine stuff, but stiff enough to stay firm when straightened.  Worked like a charm, already installed and painted!  I'll take pix for next time.
« Reply #29 on: December 18, 2012, 09:39:56 AM »
I'm not sure how I missed this one Bob, but what a wonderful job you've done with it. The marking scheme is a real eye-catcher.
