Author Topic: Holt 75 Tactor and 8-inch Howitzer Build Log  (Read 14006 times)
Re: Holt 75 Tactor and 8-inch Howitzer Build Log
« Reply #15 on: July 07, 2020, 12:48:35 AM »
The engine surprised me a bit with it's detail. I was quite impressed with it built up, straight out of the box. I had considered adding plugs and wires but those are included and after the engine is fully constructed, hardly visible, so I didn't see the point in replacing it with something more detailed. The engine fits perfectly with the radiator tank in their box.
With the engine test fitted in place, I decided to ensure that the replacement roof would line up with it. As the centre roof support beam is molded onto the underside of the kit supplied roof, it required adding one from strip stock to the roof frame.
With the frame in place, I added the exhaust stack to the engine and checked to make sure it lined up with its hole in the new roof. It did!
Images showing rolled or scrunched up curtains on the four sides of the roof frame are commonly seen, so I decided to add that detail. I used Tamiya Quick Type epoxy putty and straps made from strips of masking tape.
NOTE: Bear in mind here that the roof structure and radiator are only dry fitted in place in these images so they aren't perfectly level.
The figure is from the Stalingrad line, painted with oils and Vallejo acyrlics. At this juncture, I hadn't decided on its final position.
Thanks for looking in!
Offline kkarlsen
« Reply #16 on: July 07, 2020, 02:20:24 AM »
Great show! I love it..
Kent
« Reply #17 on: July 07, 2020, 02:33:31 AM »
I have just gone through your posts and am as impressed as ever with your Modeling skills! You are turning this one into a Masterpiece! The roof is Most impressive as is the figure !
« Reply #18 on: July 09, 2020, 12:18:05 AM »
Kent
That's good to hear Kent. You never know how these build logs might be received on an aviation site.
« Reply #19 on: July 09, 2020, 12:18:55 AM »
Thanks RAGIII!
Offline FokkerFodder
« Reply #20 on: July 09, 2020, 07:50:44 AM »
I’m enjoying it to! This has been on my wishlist for ages and your build is providing lots of great tips! Cheers Matt
« Reply #21 on: July 09, 2020, 09:07:33 AM »
Glad to hear it might be helpful Matt. Just be prepared for a lot of cleanup.
« Reply #22 on: July 09, 2020, 10:32:05 AM »
Excellent progress Chris ,
I like the detail in the kit , that engine is really nice and the curtins are a nice touch . :)
« Reply #23 on: July 09, 2020, 10:53:57 AM »
Thanks Terri!
Offline Edo
« Reply #24 on: July 10, 2020, 04:17:26 PM »
I don’t know how I missed this thread before, but i’m glad i discovered it now as it is a great build log and and a source of inspiration!
i can’t wait to see this unfold!
ciao
edo
« Reply #25 on: July 10, 2020, 08:13:07 PM »
ciao
edo
Thanks Edo!
Offline ModelCellar
« Reply #26 on: July 25, 2020, 07:12:24 AM »
Chris.
Nice work !  ...looks GREAT !!  Now I just want to see it painted and weathered =).
« Reply #27 on: July 25, 2020, 08:32:25 AM »
Chris.
« Reply #28 on: July 25, 2020, 08:40:58 AM »
Superb!
 :o
vB
« Reply #29 on: July 25, 2020, 09:12:08 PM »
