Author Topic: Collateral Damage Part 1 - 2  (Read 12117 times)
« on: May 17, 2020, 09:28:58 AM »
Still rather up set with my self over this I need to make the repairs on this one . This was one of the one which took flank ( flying remote ) . All parts have been found and for the most part clean breaks . The wing has been test fitted back in place and no putty on sanding needed , just a re-glue ! Landing gear will be a challenge ...mirco pins will be I'm thinking .....more to follow
« Last Edit: May 25, 2020, 08:43:45 AM by Terri »
Re: Collateral Damage Part 1
« Reply #1 on: May 17, 2020, 09:29:25 AM »
« Reply #2 on: May 18, 2020, 01:43:45 AM »
Good luck getting it together, Terri! But I'm sure you can do it! Marc.
Offline RLWP
  • Bodger
« Reply #3 on: May 18, 2020, 07:12:23 AM »
I hate fixing finished models. I managed to drop my WNW Pup while moving it from one shelf to another
I still haven't got around to fixing it
« Reply #4 on: May 18, 2020, 08:04:37 AM »
Will try my best Marc , thanks  :)
I dislike it at as well Richard , really ticks me off when the cat keeps breaking them  >:(
Repairs are well under way . Starting off with the landing gear glueing the pieces back together wouldn't have the same strength under weight . So pins need to be added and for this I used steel wire for this . The right side only had one break and went together quickly . The left side not so much it was in three parts which needed two pins . Still have to fix the lower hub in place . The lower brake line is missing so a new one will be made using the steel wire which will add more strength . The one tire requires paint touch up and same with the hub . Tail wheel is fixed and will be pinned back in place once more of the repairs are made . Lower wing is glued back in place and rudder . Front left leading edge needs attention , but other that everything fitted excellent !
« Reply #5 on: May 18, 2020, 08:05:03 AM »
« Reply #6 on: May 18, 2020, 08:05:32 AM »
« Reply #7 on: May 18, 2020, 08:05:57 AM »
« Reply #8 on: May 18, 2020, 08:06:23 AM »
« Reply #9 on: May 18, 2020, 08:06:47 AM »
« Reply #10 on: May 18, 2020, 08:07:12 AM »
« Reply #11 on: May 18, 2020, 08:07:39 AM »
« Reply #12 on: May 18, 2020, 08:08:04 AM »
« Reply #13 on: May 19, 2020, 04:18:03 AM »
That is looking really good, Terri! Impressive...
Re: Collateral Damage Part 1 - 2
« Reply #14 on: May 25, 2020, 08:45:35 AM »
And she is back together and on the shelf  ;D
