Author Topic: 1:48 Eduard Albatros D.III  (Read 17058 times)
Re: 1:48 Eduard Albatros D.III
« Reply #90 on: June 25, 2020, 12:12:51 PM »
See , this way I wish I had a pair for Giant Green hands , I would be smashing the paper prop ...puniy prop !
Don't give up , take a break go to home depot and pick up some veneers and start fresh with what works for you  ;)
« Reply #91 on: June 25, 2020, 01:01:44 PM »
sp,
https://www.syrenshipmodelcompany.com/milled-lumber.php
   Best veneer I've been able to find, great service and prices. Take a browse,  their thinnest Pear Wood and Alaskan Yellow Cedar are a perfect fit!
« Last Edit: June 25, 2020, 01:05:57 PM by lcarroll »
Offline smperry
« Reply #92 on: June 25, 2020, 01:44:19 PM »
Thanks Lance
I found their Alaskan Cedar, but no pear wood. I e-mailed an inquiry and will see. I appreciate the steer.
Oh, my hands aren't green, just a bit sore from ripping up a hard CAed blank. I was definitely Big Green Guy pissed though :-)
I'm checking out Lances tip, but still going to find some local veneer sources. There are a few cabinet shops locally that might sell me a piece or two to try.
sp
« Reply #93 on: June 25, 2020, 03:24:17 PM »
Sorry to hear that, mate.  Hope you can get past this problem.
Gaz
« Reply #94 on: June 25, 2020, 10:41:33 PM »
sp,
    My apologies, I should have checked earlier as I had the same experience after sending you the Post. The owner replied to me immediately that he no longer sells the Pear wood as he can't find any of decent quality anymore. Please let me know if you locate any, in the meantime I'm going to experiment with pre staining some of the yellow cedar which seems to be in good supply. I'll start "shopping around" as well.
« Reply #95 on: June 25, 2020, 10:43:17 PM »
Sorry your experiments didn't work out. On the other Hand at Least you gave it a Go! Looking forward to seeing some wood Vaneer props in the future!
« Reply #96 on: June 25, 2020, 11:04:10 PM »
Sorry the experiment didn't work out SP, I had a horrible time trying make props with card. I think you will find wood to be so much more rewarding to work with.
Offline smperry
« Reply #97 on: June 26, 2020, 05:34:57 AM »
Rick and Richie
The up side of failing is that I won't be plagued by wondering if that could have worked.
Your guys don't carry the pear any more. They only carry Alaskan Cedar. I found a place called Rocker that has a wide selection of veneers that are 0.6 mm. Hopefully this link works:
www.rockler.com/domestic-3-square-foot-veneer-packs?sid=V91040&promo=shopping&utm_source=google&utm_medium=cpc&utm_term=&utm_content=pla&utm_campaign=PL&tid=pla&gclid=EAIaIQobChMIv6Ox0ded6gIVFY3ICh0EVgYeEAQYAiABEgKxFfD_BwE
Or just Google Veneers and look for Rocker.
I will be ordering some to try.
sp
Offline smperry
« Reply #98 on: June 29, 2020, 12:32:33 PM »
Kind of a landmark day for me. Not only went RC flying in the morning, but this evening is the first time since my surgery that I have sat at the bench and worked steadily on a model for a couple of hours.
I got the U/C rigged with glue blob turnbuckles. Painted  the rear wing root fairings. Installed lower elevator PE control horns, rigged & painted same. Touched up green under stabilizer. Trimmed & painted plastic card strip used for hinges. Painted front of fuselage black so it would just show with the spinner in place. Stuck the spinner on the half dry paint.
May not be much, but it was loose ends needing dealt with and I did so in an organized manner, so yeah a good day for a change.
sp
Here it sits with all the loose ends tied up
Head on to show the UC rigging and the black behind the spinner.
Another view of the U/C rigging
The underside of the stab and fuselage. Got a bit messed up, but will look better after final clear coating. That white stripe decal gave me fits applying. Way to flimsy for my heavy hands. I was lucky to get it on with as little mess as it has. Maybe a bit of a rub with fine grit and then mask and lightly spray. OTOH, just never pick it up and look at the bottom :-)
« Reply #99 on: June 29, 2020, 04:26:22 PM »
Looks great!  My favorite Albatros livery!
« Reply #100 on: June 29, 2020, 08:50:49 PM »
Good to you getting back to normal activities SP, the Albatros is looking great. It must feel good to be back on track.
« Reply #101 on: June 29, 2020, 10:05:34 PM »
Coming along nicely, SP.
BTW - what kind of RC flying are you doing?
« Reply #102 on: June 29, 2020, 10:53:00 PM »
Great to hear, and see, that you are back at your bench and Flying RC! Your Albatros is coming along Nicely!
Offline smperry
« Reply #103 on: June 29, 2020, 11:05:01 PM »
Thanks y'all. I'm glad to be moving again.
RC-wise, I have everything from a 41% Extra and a turbine trainer down to an electric  dollar store foamboard  Flite-Test Bloody Baron. I managed not to bump the Bloody Baron into the planet yesterday. First time I have flown since January.
I also got a stack of 1/64 ply strips laminated as a practice prop blank to play at carving some while I wait on my order of light and dark veneers to arrive. I managed to find a better way of clamping the glued up stack, so that was not wasted time.
sp
Offline smperry
« Reply #104 on: July 02, 2020, 01:28:22 PM »
Worked on the top wing where something went wrong with every step.
Then I attached the lower wings at a slight dihedral as per various drawings, (harder to see in photos). I used 5 min epoxy and am giving It an hour
sp
