Author Topic: Revell 1:28 Spad XIII as Luke's plane, at least the one he was photographed near  (Read 30866 times)
I really enjoying following your build SP , the extra details real add to the over feel of the build . Looking forward on the next run .
Offline smperry
Thanks Terri, here is the next run.
Today I received an order of Albion Alloys micro tubing from M&M Models, so I decided to give the Pup a break and get back to the Spad and finish the Hisso engine I started this project by making a hash out of.
I attempted to make plugs like Des showed in his article on detailing a Hisso. I'm not that good and ended up with a modified method that worked for me. After removing the cast plugs, I drilled a 0.5 mm hole all the way through the cyl bank. The plugs were made by stringing lengths of 05mm tube onto some surgical steel wire. A little thin CA wicked into the tube secured the tubes on the wire.
The surgical steel wire was cut between the brass tubes and the resulting "double plugs" were inserted through the holes through the cyl banks.
After painting the plugs white and trimming the surgical wires to represent the tips of the plugs, the plug wire harnesses I made earlier were added and the leads trimmed. The camera may show a bit more magnification, but to the Mk.I eyeball they look good enough to me.
So I have a question to ask before it is too late to change my mind. What color should the rubber hose fittings on some of the piping be painted. They didn't put carbon black in rubber tires until after the war. I somehow don't think they were tan or pinkish gray as some WWI tires. I am thinking a reddish color as I have seen red rubber hoses. That would have come out as black on the B&W Ortho films of the day. Anyone know for sure or have strong opinions please sing out.
sp
This version of plugs and wires is Fantastic! Your change in materials and their utilization is far superior to the earlier versions. Well Done SP!
That looks great SP, looks like you're having fun adding details to the engine. I may have to steal your ideas, your solution is excellent.
Plugs look much better !  :)
Offline smperry
Here is the CSM 1:28 Hisso half a step more done than it needs to be. I will have to cut away some of the external piping in order to fit it in the model. (It won't be seen, but I'll always know it was hacked :-)
Edgar, If you are watching, the kit went together very well. There was minimal parts cleanup and the details are crisp. Highly recommended to anyone contemplating this kit.
Now it is on to fitting the engine in place and closing up the fuselage.
sp
Prop and Engine are really very impressive SP!
Offline smperry
Thanks Rick. I'm kinda proud of how the engine came out. The prop OTOH is a Digmayer hand made piece gotten years ago through CSM back when Eric was with us. (It took great modeling skill to get it out of the plastic bag and stick it on the prop shaft :-) Kinda feels like cheating, but it looks so good I don't care...much. Have to carve one myself soon.
sp
Very fine modelling. Especially on the engine.
Offline smperry
Why thank you Sir. I have a long way to go but I'm headed in the right direction. Your builds and those of other Forum members are surely inspiring me.
sp
What a great result SP, love to see careful work pay off. The added details really sing out. Prop looks totally cool!
Offline smperry
Thank you Richie. A little careful work with the dremel and the removable cowl piece fits perfectly.
Getting the correct angles on the cylinder banks is critical in getting the engine to fit. The carb and intake manifokds, 3 pcs, when assembled corectly span the cyl banks. If the manifold pipes do not exactly fall on the molded fittings for them, then the angles of the cyl banks need to be adjusted until they do match up. I left the banks unglued until I had fitted and glued the manifold. Only then did I use a drop or two of CA to hold the banks to the crankcase. That paid off as the fit was tight, but near perfect.
Now I'm going to go fight with recalcitrant Gulfhawk decals while I decide what's next with the Spad.
sp
Offline RLWP
  • Bodger
Ooo now, that is looking really nice
Really looks great in place SP! You are moving right along now!
Excellent work on getting the cowl to fit , well done SP !
