Author Topic: Sopwith Schneider, Special Hobby 1/48, Upd 14.2.2020 St Valentine's Day  (Read 34176 times)
Re: Sopwith Schneider, Special Hobby 1:48, Upd 7.1.2020 Rotary engine
« Reply #30 on: January 08, 2020, 04:45:39 PM »
Spectacular, to say the least. Everything you touch is turned in gold.
Offline jeroen_R90S
« Reply #31 on: January 08, 2020, 07:08:26 PM »
... to which nothing I can add except follow along in awe :)
Offline Robin
« Reply #32 on: January 08, 2020, 07:57:37 PM »
Wonderful woodwork, spectacular engine.
In the middle of all this nice stuff, your one euro cent coin looks a bit sad. It deserves a little polish by now. :(
Robin :)
« Reply #33 on: January 09, 2020, 01:31:48 AM »
Outstanding interior work! The engine is magnificent!
« Reply #34 on: January 09, 2020, 07:26:53 AM »
Thank you all for such encouraged words!
That's high praise! I'm speechless! Now I need a red face smily :-[
Exactly this piece of cent has a black dot of weathering - this is a reminder of the broken bottle of black Alclad primer during the creation of my Fokker as part of the Group Build - this black paint was everywhere! So I'm a bit sentimental - but you are right, I should replace it against a fresh one.
« Reply #35 on: January 09, 2020, 08:21:33 AM »
Another masterpiece on its way. Great work till now, waiting for next updates.
« Reply #36 on: January 09, 2020, 11:23:08 AM »
Genial !  :)
Sopwith Schneider, Special Hobby 1:48, Upd 13.1.2020 Closed!
« Reply #37 on: January 14, 2020, 07:27:16 AM »
Thank you Giuseppe and Terri!
Here it comes:
Closed!
... not the build report, just the fuselage - not yet, soon.
A wooden part was still missing, or was only glued crosswise in two layers. Now holes were drilled and the board painted.
To improve the illusion, I thinned out the holes from behind with ball cutters.
Some metal is also missing, steering wheel holder and pedals, here in raw form soldered from brass tubes of different thickness and wires.
After cleaning and tinning I call it done.
Before glueing the halves some washing with oil paint, a last look. The rest I built in "endoscopically" from front and top.
But now: the thing is closed! In the back I made some space for the tailplane.
The front was also made to fit with Evergreen, also a brass bearing bush was turned for the engine.
The elevator was cut off and already fitted with new hinges, at the moment just plugged in.
The aluminum cover is glued to the fuselage, already riveted in the rear part. The moulded rivets on the sides had to go away.
To adjust the float struts I glued the floats with UHU Tac on cardboard, so I can adjust the lengths well. The fuselage is carried already by the two brass pins of the rear struts - so assembling later is fun!
The aluminum side plates and the engine cowling will be one hell of a fiddle, but the engine should have room.
Offline Robin
« Reply #38 on: January 14, 2020, 07:32:40 AM »
All pretty awesome and a handful of bonus points for the polished coin!  ;D
Robin  :)
Re: Sopwith Schneider, Special Hobby 1:48, Upd 13.1.2020 Closed!
« Reply #39 on: January 14, 2020, 07:39:31 AM »
Superb modelling, Frank! ;)
This will be a show stopper  :o
vB
« Reply #40 on: January 14, 2020, 08:13:43 AM »
Damn Fine Modeling as always! Love the details and the upper cowling is Awesome!
« Reply #41 on: January 14, 2020, 10:29:11 AM »
Yup , the devil is in the details !  :)
Offline Dave Brewer
« Reply #42 on: January 14, 2020, 11:49:16 AM »
This is another fascinating build Frank,I'm constantly impressed and learning by your approach to construction issues.
Dave.
« Reply #43 on: January 14, 2020, 05:30:53 PM »
Increasingly amazing!
« Reply #44 on: January 14, 2020, 07:09:46 PM »
Wow Frank, what an incredible work on this plane!
