Author Topic: Sopwith Schneider, Special Hobby 1/48, Upd 14.2.2020 St Valentine's Day  (Read 34030 times)
With the new year I will reactivate a older project, because I want to feel and smell wood ...
Sopwith Schneider
May be some of you remember my Lebed VII project, finished two years ago. This biplane was a copy of the Sopwith Tabloid and already at this time I thought about building another one, this time as the famous Sopwith Schneider.
At the end of the build report I created the floats already during a snowy winter day. After that nothing happens ...
This Tabloid with floats and a 100 PS Gnome Monosoupape take part on the Monaco Schneider Trophy, a race about 28 laps with 10km each:
Source: kingstonaviation.org
On April 20th 1914 the pilot Howard Pixton finished aftzer 2 hours 13 seconds with a average speed of 86.78 mph. One cylinder of the engine failed after half of the laps, but with two additional laps he completed 300 km and a world record for sea planes.
References:
Windsock Mini Datafile 9 "Sopwith Tabloid"
Quelle: windsockdatafilespecials.co.uk
Windsock Datafile 60 "Sopwith Baby" with drawings of the Sopwith Schneider, but the later production version.
Quelle: amazon.com
I found also different drawings in the internet.
So far for the background.
May be this is interesting for some of you.
« Last Edit: February 14, 2020, 09:46:29 PM by Bughunter »
Sopwith Schneider, Special Hobby 1:48, Upd 2.1.2020 Main floats
« Reply #1 on: January 03, 2020, 08:02:10 AM »
Floats
At first I repeat here the steps from two years ago, to have it all at one place.
Cut stripes of plywood. 3 of them are thick enough for one float. At first glued two, drilled bling holes to be filled up with a bad alloy of solder. I want to avoid tail sitter!
After gluing the last stripe the lead is no more visible. With my small Proxxon disc sander the floats reaches the final form within seconds.
The sides are also slightly sanded to reach nearly the needed width. After that it was planked with my nice pear wood.
After the dry glue a sanded the veneer carefully to reach the contour.
For the up and down layer I had to bend the veneer with steam and glue it to the floats.
The beading was intended and mentioned the the Datafile drawing. I have to reduce the thickness further and sand the beading to the final size.
After painting nothing happens on this ...
But with the new drawings and info now I realized, that some wooden strips for easier ground handling are missing. So I removed the paint and glued very thin veneer strips to the lower surface. I was only able to do it straight with using of some Evergreen strips.
After a bit of sanding I painted the floats again.
I think that is now a good base to continue ;)
Re: Sopwith Schneider, Special Hobby 1:48
« Reply #2 on: January 03, 2020, 08:33:53 AM »
What a lovely pair of floats. And a simply super subject! I really like floatplanes and flying boats - not sure why but there is something attractive about them. I will be following this one with great interest.
Offline Robin
« Reply #3 on: January 03, 2020, 08:44:29 AM »
Lead filled floats? Frank...you're not building a U-boot. ;D
Kidding...looks fabulous. :)
Robin
« Reply #4 on: January 03, 2020, 09:51:42 AM »
This is going to be fun to follow!  Those floats are spectacular!
« Reply #5 on: January 03, 2020, 11:48:23 AM »
Very nice wood work Frank , those floats are awesome !
« Reply #6 on: January 03, 2020, 06:36:07 PM »
Like the others have said Frank, a wonderful pair of floats. This is a lovely wooden tone achieved here.
« Reply #7 on: January 03, 2020, 06:45:31 PM »
I love a bit of woodwork Frank,
Looks lovely. Could you have kept a natural wooden finish rather than paint? Not a criticism at all - just you can’t beat some natural polished wood!
Great subject..
« Reply #8 on: January 03, 2020, 08:32:17 PM »
Thank you Stephen, Robin, Bud, Terri, Andreas and Guy!
I will use a Sopwith Schneider kit from Special Hobby, but the Race version is very different to the later production version of the kit, so I have to change some things and there are no decals offered for my planned aircraft.
I hope I have enough in to avoid a tail sitter :-\
I guess this was painted a lot with spar varnish, to make it water proof. I think that look can't be reached with just polishing pear veneer.
Edit: forgot another important reason: natural veneer is very weak and damageable, also my thin airscrews, so at least the wood primer (german product name "Schnellschleifgrund") is needed to stabilize and harden it.
Now I have also birch veneer, but want to avoid to redo the covering work again without knowing in advance, if it will work with birch too ::)
Let me think about it ...
« Last Edit: January 03, 2020, 09:37:37 PM by Bughunter »
Sopwith Schneider, Special Hobby 1:48, Upd 3.1.2020 Tail float
« Reply #9 on: January 03, 2020, 08:33:35 PM »
Tail float
Following the above pattern, I glued plywood scraps again and carefully shaped them with the disc sander.
The slanted upper edge results from the fuselage shape.
On the underside I glued pear veneer and carefully sanded the edge according to the shape.
Then I bent a veneer strip over steam and glued it around the float. After drying, sand all overhangs, here the upper side:
And the bottom. Except for the coloring it can stay like this.
Will look like this. Later I will add a rudder, driven from the yaw rudder.
Again something done (was a bit sceptical, if this heavy bending is possible or not ...).
« Reply #10 on: January 03, 2020, 09:56:18 PM »
Nice work, Frank.  This will be a really nice model of the Schneider.
« Reply #11 on: January 04, 2020, 12:18:11 AM »
Incredible start to what is sure to be a Stunning Model!
Sopwith Schneider, Special Hobby 1:48, Upd 4.1.2020 Wings
« Reply #12 on: January 05, 2020, 05:50:41 AM »
Thank you for your praise in advance Ken and Rick, I hope I can fulfill the expectations ::)
Wings
The kit contains many optional parts, because every Schneider seems to be different.
2 or 4 blade propeller,
Ailerons or wing warping,
different tail units,
another cockpit cover.
Fortunately I don't need to saw out the ailerons, the Racer had wing warping.
After sanding down the rib tapes I primed the wings white.
The real colors of the Schneider Racer are open to speculation. There are some artistic works,
e.g. by Kenneth McDonough
https://pinturas-gran-guerra-aire.tumblr.com/post/184279178820/1914-sopwith-tabloid-schneider-trophy-kenneth
or here nice sketches http://speedbirds.blogspot.com/2007/09/sopwith-schneider-circa1913.html
which one can use for orientation. But some things are clear from existing pictures: here are brighter lower ribs.
Quelle: jn.passieux.free.fr
Masked and shadowed, from above:
and lower side:
Then I painted linen colors, but I was not able to show the real colors on the photos made with artificial light :(
I hope, you got a impression and it will match somehow the original plane.
Re: Sopwith Schneider, Special Hobby 1:48, Upd 4.1.2020 Wings
« Reply #13 on: January 05, 2020, 10:20:23 AM »
Hi Frank , nice results with the wings . I like it  :)
« Reply #14 on: January 05, 2020, 08:33:02 PM »
Thank you Terri!
As I mentioned there are no decals available for the Racer (really pitty, for the 3 kit variants Special Hobby provided decals printed by Cartograf). But a friend jumped in and offered to help - he created masks on his cutting machine :-* Since X-mas I own such cutting machine too, so it is another important reason to finally use the provided masks!
So the racing numbers are applied last night to the wings, using a night camouflage black by MRP:
Thank you very much, Walter!
