Author Topic: Albatros Dr.I, Eduard 1/48, Upd 28.6.2020 Suspension  (Read 36409 times)
Re: Albatros Dr.I, Eduard 1/48 Upd 18.2.2020 Tank
« Reply #45 on: February 20, 2020, 06:01:49 AM »
Beautiful work on the Tank,prop and hub, and engine Frank!
Albatros Dr.I, Eduard 1/48 Upd 23.2.2020 Engine
« Reply #46 on: February 24, 2020, 04:14:13 AM »
Thank you Rick!
Engine
After some more detailing, painting and an oil wash, this is now the result I have achieved from the lump of resin.
The other side. A hole has removed the cast-on pin and made space for the bearing deep inside the resin.
The engine is now securely glued, the propeller is just plugged on, but can turn.
A last view for goodbye ...
I had to adjust the shape of the side fairing on the engine a little bit, then the fuselage halves could be glued together. The separated rudder fin and the skid holder at the tail were also glued in, so that all "wooden parts" could be painted in one go.
From the cockpit and engine you can even see something
When the glue has hardened, I can sand and prime everything and paint the wooden look.
« Reply #47 on: February 24, 2020, 04:18:41 AM »
Truly amazing Frank, you are a master, especially in this smaller scale.  I would have believed it was 1/32.
Offline Gene K
« Reply #48 on: February 24, 2020, 05:31:17 AM »
Frank,
I continue to not be able to view any pictures that you post, and have been unable to track down why.
Can you tell me the site that hosts the pictures that you link ... or are you posting some other way?
Thanks -- I feel I'm really missing out!
Gene K
« Reply #49 on: February 24, 2020, 06:58:03 AM »
Gene,
The pictures are hosted by Google.
Sorry, I have so influence, how the links looks like, and no other storage space available.
A suggestion:
- please Quote my last update posting, then you see the source.
- copy the URL of a picture between the IMG-tags
- put it into the address line of your browser and press Enter
=> I guess the picture will be shown
I don't know, why some specific browser versions do not load the pics during rendering of the page, seems to be a bug. I heard from Safari on some iPads.
Actual browsers are working: Chrome, Firefox are working here, on my PC at work also MS Explorer.
« Reply #50 on: February 24, 2020, 08:09:07 AM »
Excellent outcome on the engine Frank. All is looking fantastic! I am looking forward to the wood painting!!
« Reply #51 on: February 24, 2020, 10:22:18 AM »
I really like the direction this build is taking so far , Wunderbar !
Terri , almost tempted to pull my out of the stash ....
Offline AndRoby67
« Reply #52 on: February 25, 2020, 02:30:24 AM »
Many compliments Frank!
As I wrote, I have this Dr.I in my future plan in 72nd scale and now it's time to follow better your next steps!
Great work!
Roberto
« Reply #53 on: February 25, 2020, 01:53:31 PM »
Really good work on engine and accessories.
Albatros Dr.I, Eduard 1/48 Upd 27.3.2020 Wooden fuselage
« Reply #54 on: March 28, 2020, 07:54:02 AM »
Oh sorry my friends - have not say thanks for your nice comments: Thank you!
After exhibiton, illness and a build of a Benz Motorwagen I decided to continue on this rare bird!
Wooden fuselage
Tried some weeks ago to mask the engine using tape, but failed. So I put it aside then ...  Tried again today with the idea to use normal paper cut in strips. Seems to work!
Here I have a lot of wood, but where to hold this beast? I drilled holes, will be used later to mount the tailplane, nut now for two needles ...
... a clamp can hold now the fuselage and is a nice handle during the paint process.
After white primer - sanding - primed again, I painted acrylic "wood base".
This time I take more case for the seams, here the lower side, looks nice and aerodynamical clean without a wing recess!
And also the upper side seems to be ok.
The next step was the wood simulation with different oils.
Have to wait now for hardening. Later clear yellow/orange will follow.
Re: Albatros Dr.I, Eduard 1/48 Upd 27.3.2020 Wooden fuselage
« Reply #55 on: March 28, 2020, 08:55:05 AM »
Really Love your wood work here Frank! I am in the same school as you apparently. Light and Dark vs Pattern!
Offline Radarman
« Reply #56 on: March 28, 2020, 08:57:21 AM »
Frank,
I'm glad you are feeling better and it's good to see you are back on track with this build.
        Have a great weekend,
        Kevin
« Reply #57 on: March 28, 2020, 09:37:41 AM »
Well done on the wooden finish, Frank!
« Reply #58 on: March 28, 2020, 11:22:07 AM »
Nice variations within the wood tones Frank . I have used that method of holding subjects for paint . Works like a charm !
Offline AndRoby67
« Reply #59 on: March 28, 2020, 10:03:26 PM »
Hi Frank!
Wooden panels realized in a beatiful way!
Veener is not so "heavy", look good for the scale.
Congrats!
Roberto
