Author Topic: Albatros W.4, Eduard 1/48, Update 24.11.2019 Final parts  (Read 39263 times)
Offline UFAG
Re: Albatros W.4, Eduard 1/48, Update 23.9.2019 Wood paint
« Reply #30 on: September 24, 2019, 05:54:42 AM »
Seat cushion- perfect...Prop-perfect...Foil better then painting I think, might try a slightly thicker foil or very thin lead foil, like from a champagne bottle cap....
« Reply #31 on: September 24, 2019, 06:18:57 AM »
Lance, the foil is ordered.
In your big scale real brass should be possible. The result of Proper plane looks great:
See here:
https://properplane.com/index.php?route=product/product&path=70_59&product_id=122
But an extra $25 (for a pair) is not just a little bit ::)
Prop-perfect...
Nearly, I was surprised by the heavy grain on one side in the dark wood. It was not visible on the outside of the veneer, but wood is a product made by nature, so you will never know before what you will get ;)
So with thicker foil it was hard to close it and bring it to the multiple curves of the blade. Other material has to be painted to brass again. The bare metal foil has the big advantage of easy cutting with sharp scalpel on the object.
An in 1/48 the blade tip is not very big as it looks on the macro picture ???
« Reply #32 on: September 24, 2019, 06:27:54 AM »
Also take note, the Bare Metal foil will show the wood grain through it, so smooth off the area that it will be applied.  You could fill in the grain with clear varnish rather than sanding it smooth.
« Reply #33 on: September 24, 2019, 09:15:20 AM »
Frank,
    I have a package of the product below and the .001 and even .002 mm stock looks to me like it might work in 1:48 as well.
http://www.ksmetals.com/30.html
    You can find the product under "Metal Sheets" on the side menu, Stock #258 Brass Shim. As you'll see there's 4 Gauges included. I used to see it a lot in Hobby Shops here in Canada.
    The advantage of the Bare Metal Foil would be the adhesive which should make it far easier to apply. The proper Plane "boots" look excellent, this is going to take some experimenting!
« Last Edit: September 24, 2019, 09:22:20 AM by lcarroll »
« Reply #34 on: September 25, 2019, 03:28:25 AM »
Yes Ken, I use normally a clear wood primer to fill it.
The german word "Schnellschleifgrundierung" means "quick sanding primer":
Source: clou-shop.eu
The broken experimental prop used yesterday was not a nice example ::)
Thank you Lance for another hint.
I really like the discussion of such technical issues here. Thank you very much for your great support!
Offline calumet
« Reply #35 on: September 26, 2019, 10:23:52 PM »
Outstanding work as always....!
Hans
Albatros W.4, Eduard 1/48, Update 26.9.2019 Lathe tooling
« Reply #36 on: September 27, 2019, 05:28:27 AM »
« Last Edit: May 31, 2022, 01:29:21 AM by Bughunter »
« Reply #37 on: September 27, 2019, 05:46:34 AM »
That is an amazing piece of work and testament to your attention to detail!
Re: Albatros W.4, Eduard 1/48, Update 26.9.2019 Lathe tooling
« Reply #38 on: September 27, 2019, 11:36:31 PM »
What a clever idea, dear fellow  ;D
All the best
« Reply #39 on: September 27, 2019, 11:58:23 PM »
Super work on this, Frank!
vB  ;)
« Reply #40 on: September 29, 2019, 04:30:02 AM »
Thank you my friends!
In mean time the golden foil arrived. I noticed, that is still an alu foil but plated or painted in this golden tone. So I'm not sure yet if I will use it or not.
« Reply #41 on: September 29, 2019, 09:09:12 PM »
Brillant !
Albatros W.4, Eduard 1/48, Update 29.9.2019 Fuel selector panel
« Reply #42 on: September 30, 2019, 03:49:44 AM »
« Last Edit: May 31, 2022, 01:29:30 AM by Bughunter »
Re: Albatros W.4, Eduard 1/48, Update 29.9.2019 Fuel selector panel
« Reply #43 on: September 30, 2019, 04:14:26 AM »
Your detail work and painting Never fail to amaze Me Frank! Beautiful work!
« Reply #44 on: September 30, 2019, 05:04:15 AM »
Stunning detail Frank    :D
