Author Topic: Albatros W.4, Eduard 1/48, Update 24.11.2019 Final parts  (Read 39265 times)
Offline AndRoby67
Re: Albatros W.4, Eduard 1/48, Update 9.9.2019 Wings
« Reply #15 on: September 10, 2019, 09:53:34 PM »
Outstanding work!
With some tricks that everyone of us may use for next projects.
The W.4 was a beautiful seaplane and your work will delight us.
Roberto
Re: Albatros W.4, Eduard 1/48, Start 8.9.2019 Floats
« Reply #16 on: September 13, 2019, 03:45:58 AM »
Thank you for your comments Lance, Ken, Rick, Terri, Bud and Roberto!
Is this an early version or late version? (the early version has the radiators on the sides of the fuselage).
Ken, I mentioned the serial numbers last time, but I want to point out more major differences between the 5 (ore more) production batches (additionally there are some prototypes):
- single or twin machine guns
- side radiator or airfoil radiator
- ailerons only on upper wings or also on lower
- various shapes of floats due to damages
- different paintings and camouflage fabric applications
Everybody needs a floatplane.
You have already a floatplane. And what a floaplane that is, a winning one! 8)
SCNR
« Reply #17 on: September 13, 2019, 04:07:47 AM »
Super job Frank,
(As always)
« Reply #18 on: September 13, 2019, 06:05:55 AM »
Yes, there are numerous 'versions' of the W4.  I have done a little research already and they were constantly changing and improving it.
( I need another floatplane  ;) )
« Reply #19 on: September 13, 2019, 06:42:00 AM »
All good model collections need both floatplanes and flying boats! Not to mention some pushers!!
I really like the markings Frank, and the extra details on the ailerons are taking this model to the usual very high standards that I associate with all of your models.
Albatros W.4, Eduard 1/48, Update 22.9.2019 Airscrew
« Reply #20 on: September 23, 2019, 02:55:53 AM »
« Last Edit: May 31, 2022, 01:28:42 AM by Bughunter »
« Reply #21 on: September 23, 2019, 06:39:46 AM »
Frank,
    I've been meaning to order some gold of this product for the same purpose. I've used the chrome and matte Aluminum versions and like them a lot, it might provide a solution if given a coat of clear or flat satin once applied.
https://www.bare-metal.com/bare-metal-foil.html
Re: Albatros W.4, Eduard 1/48, Update 22.9.2019 Airscrew
« Reply #22 on: September 23, 2019, 08:14:26 AM »
That seat cushion looks real Frank! Wonderful sculpting there. The propelloer also looks fabulous (and by the way I like a nice behind too!) I cannot comment on the brass tip because I have no experience of this but you could try Lance's idea.
« Reply #23 on: September 23, 2019, 09:49:50 PM »
This would be a good application for Bare Metal Foil. I have used a lot of it for car modeling.
« Last Edit: September 23, 2019, 09:55:33 PM by kensar »
« Reply #24 on: September 23, 2019, 10:23:10 PM »
The prop is amazing as always. I absolutely love the seat and cushion. Your builds are always great to follow along with and learn from!
« Reply #25 on: September 23, 2019, 11:07:20 PM »
Great detail Frank, love what you have done with both the seat and propeller.
« Reply #26 on: September 23, 2019, 11:59:50 PM »
Great stuff as always, Frank. I also would go with masking and painting the brass propeller tips. Your seat and cushion look fantastic. Maybe some careful highlighting with grey tones to show off all the beautifully sculpted wrinkles?
Best regards
« Last Edit: September 24, 2019, 08:27:43 PM by Borsos »
Albatros W.4, Eduard 1/48, Update 23.9.2019 Wood paint
« Reply #27 on: September 24, 2019, 03:51:02 AM »
« Last Edit: May 31, 2022, 01:28:58 AM by Bughunter »
Re: Albatros W.4, Eduard 1/48, Update 23.9.2019 Wood paint
« Reply #28 on: September 24, 2019, 05:18:58 AM »
Outstanding work on the fuselage, tail surfaces, and the interior painting...of course we expect No Less from you  8)
« Reply #29 on: September 24, 2019, 05:44:49 AM »
Frank,
    I suspect the gold version of the Bare Metal Foil will be very bright and shiny however some subtle work with grey or almost black "filters" might do the trick. I really like the results you produced with the silver experiment, it looks very good! I'll be following closely to see how this works for you.
