Author Topic: TP's WNW 1/32nd Scale Biff  (Read 56064 times)
Offline Trackpad
Re: TP's WNW 1/32nd Scale Biff
« Reply #255 on: September 25, 2013, 09:50:39 AM »
Hello, Everyone,
And thanks for your very encouraging comments. I'll post a few comments on EZ Line shortly: not too much actually, but I worked out an installment method that more or less works for me. More anon!
Now, I don't know how this happened, but I do know that it is definitely not the right and proper way to go about this, but...well... there I had the Biff on the jig with the forward cabanes glued. And it looked so d**n close to getting the upper wing into place (at least, the first phase looked close), so I...uhh...got the rear cabanes fitted into the upper wing centre section and then went the whole nine yards and glued the upper ends of the rear cabanes and then started muttering all sorts of prayers to the plastic Gods! There: wing fitted!! No measurements, no rigging, no alignment, no compass (!): nothing but a totally foreign "git 'er done" attitude! ::)
So, as you can see from this uncharacteristic burst of enthusiasm, the wing is now in place, pretty much centered, but with a slight misalignment (upper photo). That said, I fully expect that the wings will align nicely when the interplane struts are fitted, as I can already easily nudge the upper into a worthwhile position. Incidentally, the rear cabanes are not glued at the fuselage end, so the slight leeway that this gives will also help.  If I have to, I'll anchor the wings into alignment and apply the glue, but I don't expect any problems. Rigging? slow and easy, one line at a time, working from fore and aft center-line outwards.
So there you have the most recent update: completely tosses Des' methods and techniques right out the window!  ;) This better work, or he and others will never tire of telling me, "I told you so!" And I'll deserve it!
Thanks for visiting!
I wonder if I can do this with crossed fingers...!  :D
Cheers!
« Reply #256 on: September 25, 2013, 10:57:21 AM »
Kinda like the scene in Animal House where they are building the Death Machine: Belushi painstakingly measures the windshield and then smashes it in with a sledgehammer...   :D
Anyway, looks great Gary; slight misalignment only really evident after you pointed it out... I'm sure you will reef her into shape :)
« Reply #257 on: September 25, 2013, 11:41:15 AM »
Nicely done, Gary.  Looks like the struts won't be much of a problem at all.
Offline Dal Gavan
« Reply #258 on: September 25, 2013, 11:41:54 AM »
Gary, if the kit wants to be built, it will be built.  Just as when they don't want to be built, they let you know.  What makes you think the modeller has any choice in the matter?  ;D
It's looking good, mate, and I know you'll get it all squared up.
Cheers.
Dal.
« Reply #259 on: September 25, 2013, 10:40:46 PM »
Looks as though your mounting method will work FINE! Great progress!
« Reply #260 on: September 26, 2013, 12:02:09 AM »
Gary,
   Great progress, I'm starting to feel I'm in the "lag" position again! I really believe that the Assembly Jig is a "can't go wrong" step in the process if you take your time, although I short-cutted the process and got away with it as well. Looking mighty fine!
Lance ;)
« Reply #261 on: September 26, 2013, 02:34:32 AM »
Nice!  I sure hope that when I get around to building my Ninak, the top wing goes on so easily.
Offline Epeeman
« Reply #262 on: September 26, 2013, 05:15:10 AM »
Lovely progress, Gary.
Yes, EZ line has it's uses but it can be a real pain to handle as well!
Offline Trackpad
« Reply #263 on: September 26, 2013, 06:05:58 AM »
Thanks, everyone, for your very kind comments. As a bit of additional information, I dry-fitted two outer interplane struts last night, one on each side. This morning they were both still in place, and the misalignment is noticeably reduced. It looks right now as if the balance of the struts will complete the misalignment fix. More later. Fingers crossed!  :)
Cheers!
« Reply #264 on: September 26, 2013, 07:36:38 AM »
Looks great Gary,
I have history with top wing issues! I must learn how to build a jig..
Looking forward to seeing her rigged.
Offline Trackpad
« Reply #265 on: October 23, 2013, 06:31:15 AM »
Hi, Troops,
Just one key update item to pass on today:  THE WING IS ON!!
It's not neat, and it's not pretty, but it's on and it actually lines up with the leading edge of the lower wing rather well (Luck of the partially Irish, I guess!). I know that I'll have challenges with the rigging, the exhaust extensions and a few other topics, but it felt just great to get that upper wing in place!  I'll be continuing with the fitting of various bits and bobs, then it's on to the engine compartment, exhausts (extended), rigging, Scarff Ring...and we're done!  8)
Cheers!
« Reply #266 on: October 23, 2013, 07:35:48 AM »
Great to see the top wing in place Gary, that is one less worry on your plate. It doesn't really matter what technique you use to build these models as long as it works for you, and this apparently has. Now for the rigging, this is the part I always look forward to with my builds, hope you have as much fun as I did when I built mine.
« Reply #267 on: October 23, 2013, 09:16:29 AM »
Congratulations, Gary!  That's a HUGE step.  She's looking amazing.  Your shading is perfect.
« Reply #268 on: October 23, 2013, 10:10:35 AM »
Going from my experience, once the wing actually gets mounted, and if I am Lucky lines up, it looks as though you have this one NAILED! Congrats!
Offline LindsayT
« Reply #269 on: October 23, 2013, 11:22:11 AM »
Virtual high five, buddy! Great job.
LT
