Author Topic: Sopwith 'Swallow' 1:32 scale  (Read 36602 times)
Re: Sopwith 'Swallow' 1:32 scale
« Reply #165 on: September 26, 2019, 11:02:20 PM »
Beautiful work Mike!
« Reply #166 on: September 26, 2019, 11:12:11 PM »
Mike, its not clear to me in the photo but on the elevator control horns, did you drill one hole for both the control line and bracing line to pass through, or are there two holes?
Excellent detailing, BTW.
Hi Ken,
The actual control horns for the elevator had two cable attachments.
The cables from the fuselage were attached to the top of the control horns.
The cables from the horns and through the elevator were attached to the rear of the control horns, but part way down the rear edge.
However, I've found that drilling a hole through the control horns for attaching the rear cables tends to weaken the plastic and can cause the horns to distort or break when the lines are tensioned.
Instead I drill just the one hole at the top of the control horns and attach both cables to it.
As the rear cables are angled downwards, it still gives the impression that the line is attached farther down the rear of the control horn than it actually is,
« Reply #167 on: September 27, 2019, 04:06:14 AM »
Okay, thanks for the clarification.  I just drilled another set of holes on the control horns of my Sopwith Pup for the bracing cables, but I'm afraid the horns are now too weak for rigging.  We'll see how it works out.
« Reply #168 on: September 27, 2019, 04:27:13 AM »
You should be OK provided not too much tension is applied that may pull through the drilled hole or damage the horns.
« Reply #169 on: September 27, 2019, 05:13:39 AM »
The wing is now fitted onto the fuselage cabane struts.
Also fitted are the ailerons and the over wing cable support pylon.
Now to complete all of the wing rigging,
« Reply #170 on: September 27, 2019, 05:49:12 AM »
Not much to say other than your build continues to be Brilliant!
« Reply #171 on: October 01, 2019, 10:04:41 PM »
The final rigging is now complete.
This includes:
Aileron control lines from the cockpit to the underside of the wing.
Cabane strut side and front cross bracing.
Over wing landing wires.
Under wing landing and double flying wires.
I'll post the completed model shots once I've finished the figure and display base,
Offline Robin
« Reply #172 on: October 01, 2019, 10:53:16 PM »
Beautiful work on the rigging and beautiful in general. :)
A question...what's the white thing "inside" the machine gun?
Robin
« Reply #173 on: October 02, 2019, 12:04:39 AM »
Hi Robin,
I'm not sure what you are referring to.
Possibly light reflection from the grid vents on the machine gun cooling jackets?
Maybe the ring gun sight, located inboard from the right machine gun?
Offline Robin
« Reply #174 on: October 02, 2019, 12:31:26 AM »
I guess it's reflection...
This is what I mean.
Robin  :)
« Reply #175 on: October 02, 2019, 01:50:47 AM »
Hi Robin,
Yes that's it - light reflection when taking the shots,
« Reply #176 on: October 02, 2019, 02:54:36 AM »
Awesome rigging Mike! Simply Brilliant Build!
« Reply #177 on: October 02, 2019, 04:27:58 AM »
What a superb piece of modelling. The  struts and support pylon are as good as or better than any that you would get in a kit and the rigging sets it all off brilliantly.
« Reply #178 on: October 02, 2019, 11:23:02 AM »
I second this , very well done Mike  :) :) :)
Offline dtomko
« Reply #179 on: October 02, 2019, 12:55:23 PM »
Mike, just absolutely brilliant work!  How did you attach the rigging to the top of the pylon on top of the wing?  I never found a good photo of that.
Drew
