Author Topic: Merged: Old Aircraft in Pixels posts  (Read 23504 times)
  • Moderator
Aircraft in Pixels Albatros Summer Sale
« Reply #30 on: June 22, 2019, 01:45:31 AM »
As part of the Itch 2019 Summer Sale, Aircraft in Pixels: Albatros D.V/a is 50% off through July 1st
https://bomonroe.itch.io/aircraft-in-pixels-2
Offline Gene K
Re: Aircraft in Pixels Albatros Summer Sale
« Reply #31 on: June 22, 2019, 01:48:20 AM »
What is Aircraft in Pixels No.1?
Gene K
  • Moderator
« Reply #32 on: June 22, 2019, 08:19:37 AM »
Gene K
Good question -- it was a project I did about 10 years ago.  The subject was the Messerschmitt Bf-109e. It ran on Facebook (as an imbedded app) and also as an iPad app. It was the original basis for this new iteration, although in the end I ended up scrapping it completely and rewriting it from the ground up.
  • Moderator
« Reply #33 on: June 22, 2019, 08:27:31 AM »
PS -- I've already revealed what Aircraft in Pixels #4 will be -- The Fokker Dr.I -- but can you identify what #3 is?
  • Moderator
Re: Aircraft in Pixels No. 2: Albatros D.V Upper Wing Framework
« Reply #34 on: June 23, 2019, 10:28:39 PM »
first pass texturing the upper wing framework for the Albatros D.V/ D.Va. A few details subject to change...
Re: Aircraft in Pixels No. 2: Albatros D.V Early-ish Bird Special
« Reply #35 on: June 23, 2019, 10:42:27 PM »
Bo, if you could now invent a export option "Export to the real world" and I can put the result to my glass cabinet, that would be nice ;) 8)
If that is not possible, I would stay in the real world and try to reach, what you have created virtually.
Your pictures are looking sooo real ...
  • Moderator
« Reply #36 on: June 24, 2019, 01:35:56 PM »
Cheers Frank! I know you are joking, but that day may be closer than you think! We’re already at the point where hi rez desktop printers are entering the true consumer price range; full color 3D printers exist but the quality is fairly awful... but please remember back not that very long ago when the same was said about 2D color printers!
  • Moderator
more upper wing framework
« Reply #37 on: June 25, 2019, 12:24:10 PM »
completion of the D.V style aileron frameworks and pulleys leaves the upper wing structure substantially done...
