Under Construction
Aviatik Berg D.I//Flashback//1:48 no. 101.09
3
4
Topic: Aviatik Berg D.I//Flashback//1:48 no. 101.09 (Read 10722 times)
KrzysiekK
September 21, 2017, 05:22:13 PM »
Good Day!
Being encouraged by Des with D.I I have decided to pick up mine from the stash. I am going to do D.I base on the rough kit manufactured by Flashback. First impression is rather optimistic but it would definitely need some amendments. The resin engine looks like..I am not able to give any resemblance but I do have some old resin AD purchased long time ago, so those will be my footing for adjustment.
regards
K
coyotemagic
Re: Aviatik Berg D.I//Flashback//1:48 no. 101.09
September 22, 2017, 02:43:44 AM »
I'm looking forward to following along, K. I have this one in my stash, so I'll be taking notes.
Guest
September 22, 2017, 03:59:06 AM »
Nice, I will follow too, since I have the kit 8922 (the one with the big colorful decal) in my stash.
Please report pitfalls!
KrzysiekK
September 22, 2017, 04:11:20 PM »
thanks guys,
At the beginning I decided to alter just top of the engine being visible after assembly. But once started I have done all necessary amendments and here you have the results
regards
K
andonio64
There's no hurry
September 22, 2017, 05:11:59 PM »
Great start on the engine, K...
This is a plane I like very much, will follow with high interest.
I have a
HIPPO kit
Antonio
xmald
September 22, 2017, 05:23:42 PM »
A very nice AD indeed. The blob from the box is useless so good that you`ve decided to replace it.
Best regards
Filip
Juan
All gave some, some gave all.
Reply #6 on:
September 22, 2017, 08:42:12 PM »
Great start. The engine looks wonderful.
Reply #7 on:
September 23, 2017, 05:51:10 AM »
Awesome engine K!
KrzysiekK
Reply #8 on:
September 24, 2017, 07:39:22 PM »
Thanks!
First attempt for woodgrain cockpit structure is done. After drying I going to do little touch-up. The woodgrain pattern in lower part might not be correct vs panels structure but I would not pay special attention as barely visible after assembly
also prepared the pilot seat
regards
K
Reply #9 on:
September 25, 2017, 01:38:28 AM »
Looking great K!
KrzysiekK
Reply #10 on:
September 27, 2017, 05:30:37 PM »
thanks!
In the meantime I decided to go for wooden carved prop - 2nd attempt
Knolley –Jaray requires little more sanding and should be ok
regards
K
KrzysiekK
Reply #11 on:
October 03, 2017, 06:59:57 PM »
Keep on doing..
The dashboard is ready and implemented with all stuff into the fuselage half. I have enhanced the steering wheel, added the magneto and wires
regards
K
andonio64
There's no hurry
Reply #12 on:
October 03, 2017, 07:03:05 PM »
Wow K, great work on the interiors!!!
Reply #13 on:
October 04, 2017, 07:57:57 AM »
Gorgeous interior K. Your prop is awesome! Well done.
Des
Reply #14 on:
October 04, 2017, 01:06:42 PM »
The instrument panel turned out really well as did the rest of the interior, nice work on the propeller also.
3
4
Under Construction
