The last few weeks have been spent “learning” (also known as redoing the same thing over and over again). Ran into a few problems. If anyone has some advice for avoiding them in the future, I’d be very appreciative.
I glued the fuselage halves together. I had some problems with the joint between the two halves. There is a raised strip running down the joint, and I was careful not to sand it off. In the end it probably would have been easier to sand it flat and replace it with a strip of styrene that also would have covered the seam. I painted the silver grey with drooling bulldog paint, and was very happy with the result- great paint.
Then test I fit the lower wing. At that point I saw that I was going to have a significant joint visible on the bottom where the wing met the fuselage in front and back. As best I could tell, this was not a place where there was supposed to be a visible seam. This led to a multiple rounds of filling and sanding. I had taken off the masking over the engine and cockpit, but thought I could just generally mask over the area as the paint in the general vicinity hadn’t been affected by the sanding and priming. When I finally got the area adequately filled and repainted, I discovered there had been enough paint buildup at the edge of the masking that I had a visible line. It took a few repetitions of sanding with 1000+ paper and repainting to get rid of it.
There was also a big dust problem (lint from my daughter’s quilt stuffing) that took a fair amount of touching up. She went back to college today. I spent a while vacuuming. Dust should be back under control until school vacation.
When I took my pictures I found an area where I didn’t sand well enough, but it is time to move on.
I’m hoping the white primer works well under the lozenges. I just realized it will be very visible if I get a gap between the decals, so I hope they fit well. I still have time to repaint another color if anyone has a better suggestion. I had thought it would work well to not change the decal colors.
I knocked one of my spark plug wires loose when I was painting. When I first put them on, I had a terrible time with super glue, which didn’t want to adhere to the wire coating. I tried gator grip acrylic, which worked great. Would have saved me a lot of tedium the first time around.
