Author Topic: Dual Build: Roden 1/32nd Albatros DIII (OAW): Jasta 10, WNW ALbatrosDV: Jasta11  (Read 90624 times)
Well it has been a few days since I finished the triple build so here is my next project. As far as I know Roden is the only company to accurately depict the nose panels on an OAW DIII. That being said they missed on a couple of details. The most obvious is the wing radiator which is oversized. I am posting a photo of Bos radiator over an enlarged drawing from the Data file. As Ray gave permission to do this in another thread I am assuming he has no issues here. If so I will gladly delete the photo. I am also posting a photo of the kit rudder with an outline from the WNW Albatros DV rudder drawn on. If I am correct they should be the same size?
So my first work will be to correct the radiator. I will probably use the WNW radiator and save the Bo version for the WNW kit.
« Last Edit: April 14, 2018, 07:54:55 AM by RAGIII »
Offline Iancshippee
Re: Roden 1/32nd scale Albatros DIII (OAW): Jasta 10
« Reply #1 on: July 25, 2017, 10:22:19 AM »
Looking forward to this one! I'm not a huge Albi expert, but I think you are right about the rudder size.
« Reply #2 on: July 25, 2017, 10:07:04 PM »
Ooh lovely,
I'd love a WW D.III
« Reply #3 on: July 25, 2017, 11:08:42 PM »
coolio rick, this is a fun kit to build. will enjoy this build
« Reply #4 on: July 26, 2017, 12:22:32 AM »
Thanks Ian, pretty sure they were interchangeable.
Ooh lovely,
I'd love a WW D.III
Thanks for looking in and the encouragement Guy!
Thanks, greatly appreciate you looking in! Having built the DIII early and DI, I agree completely about the FUN!
« Last Edit: July 28, 2017, 02:39:50 AM by RAGIII »
« Reply #5 on: July 26, 2017, 04:22:57 AM »
How great to see this kit being build by your magic hands, Rick. Can't wait to see its yellow nose...
« Reply #6 on: July 26, 2017, 03:38:06 PM »
Oh rick, this will be an other brilliant build I have to follow!
Bye,
« Reply #7 on: July 27, 2017, 02:17:00 AM »
Hi Rick:
This was one of my first WWI builds.  I will be following along to watch what you do.  These Roden kits, albeit not up WNW standards, turn into a nice model.
Are you going to do it in the "Candy Striper" scheme?  I found it extremely challenging to paint the stripes and keep them evenly spaced, still a striking scheme.
« Reply #8 on: July 27, 2017, 05:00:44 AM »
I too am looking forward to this project Rick. If it is only half as good as the triplanes it will still be a front runner in my estimation. If you do choose the red/white stripe scheme that will be a real challenge - but I'll bet you will get it right all the same.
« Reply #9 on: July 27, 2017, 06:22:21 AM »
I too am looking forward to your progress on this kit.  Your modifications will be going into my scrapbook for future reference/use.
« Reply #10 on: July 27, 2017, 08:17:39 AM »
Thanks for the encouragement guys!
 Mark,
I remember this beautiful build! Back in the Old Aeroscale days IIRC.
« Reply #11 on: July 27, 2017, 12:59:57 PM »
Yes Rick:   It was my first or second foray into WWI, it still graces my shelf here in AZ.  I am looking forward to see what you do with this old 'chestnut' as it is a pretty decent kit.
« Reply #12 on: July 29, 2017, 04:49:50 AM »
I have begun the work on fitting the new radiator. I outlined the new radiator with a scribing tool in its proper location. Then I used a RB productions saw to cut out the opening. I test fitted constantly as I went through the process. The photos show the initial rough cut and dry fitting of the replacement. I am also including shots of some of the PE goodies I will use. Part of Poland and the PE from an Encore Albatros DII. I will pick and choose the pieces I want to use.
Since I took the photos I have gone back and Tweaked the location. I moved it back a fraction and made sure all was aligned properly.
PS: The radiator PE on the Part set is oversized just like the kit. The Encore PE Radiator is pretty close to being correct but represents what I believe to be an earlier version.
« Last Edit: April 14, 2018, 07:57:47 AM by RAGIII »
« Reply #13 on: August 03, 2017, 08:44:57 AM »
I have fitted the WNW radiator to the Roden wing. The primer shows I need to do a little more touch up and tweaking.
« Last Edit: April 28, 2022, 11:39:53 PM by RAGIII »
« Reply #14 on: August 03, 2017, 10:16:53 AM »
Looks like it belongs Rick.  I will be following your build.  I like these Roden kits, although haven't done in awhile, but; they build into a nice model and yours are always outstanding.
