Author Topic: Sopwith Pup, Eduard 1:48  (Read 9298 times)
« on: May 29, 2017, 02:00:47 AM »
My lately finished model is one of the first Eduard kits in 1/48: the Sopwith Pup
May be someone now the kit, plastic short run but great PE. I added a Small Stuff rotary (which is able to rotate here), a Vickers from a PE set of Parts, the new Eduard steel seat belts and decals provided by Pheon. I replaced some parts by brass ones and created many wooden parts like airscrew, struts, gear, cockpit cover ...
The paints re Gunze, Alclads and oils.
You can see trough the Vickers:
Please note the open tail with wooden/brass skid assembly:
View from below:
The back side of the rotary:
Sopwith Pup, Eduard 1:48, some Details
« Reply #1 on: May 29, 2017, 02:01:59 AM »
And a second pot with some details ...
wooden cockpit cover:
Control soldered from brass tubes:
Airscrew with engine:
Soldered Vickers:
Wooden/brass grear with half axles
Opened windows in wing:
The cooling opening:
A terminal for the RAF wires (I use this flat EZ-line for this), raw ...
... and in use:
Re: Sopwith Pup, Eduard 1:48
« Reply #2 on: May 29, 2017, 03:21:16 AM »
  Frank,
Another Outstanding project my friend. Well Done again!
« Reply #3 on: May 29, 2017, 05:36:04 AM »
You don't stop to impress us. Very nice Pup, you made a real gem out of that old kit.
Borsos
« Reply #4 on: May 29, 2017, 05:54:36 AM »
Thanks!
This will stop for sure, because my stash is much bigger compared to finished models ;D
« Reply #5 on: May 29, 2017, 07:17:32 AM »
Amazing detail in 1:48 scale, your soldering skills are excellent, this is a superb looking model, well done Frank.
Online Juan
« Reply #6 on: May 29, 2017, 10:24:56 AM »
Beautiful job, love what you have done with her.
Offline GrahamB
« Reply #7 on: May 29, 2017, 10:30:44 AM »
Great work and detailing.
GrahamB
« Reply #8 on: May 30, 2017, 02:22:32 AM »
That is jaw dropping. The amount of detail and the finish are just amazing.
« Reply #9 on: May 30, 2017, 03:57:45 AM »
You made my day - thank you!
At the end I used only 6 plastic parts of the kit :o But with the PE and all added details I really love the outcome. And as far as I know there is still no modern kit of a Pup in 1/48.
May be I should mention, that the stitching on fuselage and cockpit leather are Eduard PE for 1/72. Looks better compared to the 1/48 ones.
« Reply #10 on: May 30, 2017, 08:18:58 AM »
Another great model, quite a collection you are showing us .
« Reply #11 on: May 30, 2017, 07:32:09 PM »
Wow, you are an other master modeler. Outstanding!
« Reply #12 on: May 31, 2017, 01:28:17 AM »
Truly brilliant Pup, Frank!  You are a master modeler and magician with a soldering iron.
« Reply #13 on: May 31, 2017, 03:35:49 AM »
Thank you all!
Bud, in usage of a iron I was drilled during apprenticeship training as telecommunication technician 8) Later I studied electronics.
« Reply #14 on: June 12, 2017, 11:48:10 PM »
Yep! What my Amigo Bud said and then some!
