Author Topic: My First WNW: the RFC Pup  (Read 13610 times)
Re: My First WNW: the RFC Pup
« Reply #30 on: June 18, 2017, 02:47:16 PM »
Brilliant work on the innards, Zac!  Looking forward to more.
I agree with Bud completely!
« Reply #31 on: June 28, 2017, 12:09:08 PM »
Thank you, gentlemen! I'm very humbled by all this praise coming from modellers whose work I've admired immensely. Thank you.
The fuselage is together! At least, the sides are in place with the cockpit between:
After this photo I did a little PSR on the spine to get rid of the seam - more work is required on the belly - and painted on one coat of Humbrol Matt Cote. This weekend the sides will get Gloss Cote followed by decals. I've also rigged the rear section of the fuselage to match one of Jamo's photos - the moulded-on wires just weren't enough for me. I'll try and get a photo of this area to share.
After decals on the fuselage I'm aiming to add the forward decking (already Matt Coted) and horizontal tail.
« Reply #32 on: June 29, 2017, 11:29:32 PM »
I like your color choice for the Pup! Looking great!
« Last Edit: June 30, 2017, 11:45:13 AM by RAGIII »
« Reply #33 on: June 29, 2017, 11:40:40 PM »
Coming along quite nicely.   :D
« Reply #34 on: June 30, 2017, 06:55:55 AM »
Thanks gents!
As promised, here's a couple of rather close-up photos of the rearmost fuselage rigging. Please excuse the CDL paint - this was a rough coat to check if my PSR had paid off (it had).
Yesterday I got off work early so spent a bit more time on the Pup. Part of this was dryfitting the turtledeck. The fit's not great for me so there's some investigation to be done before it goes on for good.
« Reply #35 on: June 30, 2017, 07:20:43 AM »
Fantastic top decking, Zac!
Offline Matt
« Reply #36 on: June 30, 2017, 07:54:43 AM »
Looks good..
Just a little paint on mating surfaces is enough to throw WNW's engineering out and produce an unexpected fit problem. That's what I'd check first.
Matt
« Reply #37 on: June 30, 2017, 09:32:14 AM »
Thanks Matt. I'm wondering if it's the paint on the cabanes - I can press down on the piece to make the gaps go away, but it doesn't feel right and I'm loathe to use superglue in such a visible area.
Thanks Bud! It's my first experiment with PrzemoL's yellow base idea (I think it was him). I wasn't happy with my attempt at first but it's grown on me! I figured it would make a nice change due to the cockpit framing and struts all having an XF-59 base, just something to break up the monotony.
« Reply #38 on: June 30, 2017, 11:27:31 AM »
Zac,
    From what I can see in the photo and having built this one I believe it's interference from the cabanes; enlarging their cutouts in the cowling a bit should help. It's coming along very nicely.
Offline aliluke
« Reply #39 on: June 30, 2017, 04:24:48 PM »
Hi Zac
Most of your photos seem to have disappeared...
Alistair
« Reply #40 on: July 01, 2017, 12:01:30 PM »
Unfortunately Photobucket has decided to charge for the privilege of linking images, and I can't afford US$300 per year for that, so I'll take some fresh photos and then start fresh with Flickr.
« Reply #41 on: July 01, 2017, 01:19:08 PM »
Untitled by ZYates87, on Flickr
I think I'll need to play around with Flickr's settings.
« Last Edit: July 01, 2017, 01:24:53 PM by KiwiZac »
Offline Alpha Delta 210
« Reply #42 on: July 01, 2017, 06:20:58 PM »
Great work. The wood effect is very convincing.
« Reply #43 on: July 02, 2017, 08:53:12 AM »
Excellent wood effect on the coaming! How are you doing with the fit?
« Reply #44 on: July 02, 2017, 04:04:01 PM »
Thanks guys!
I took Lance's suggestion and played around with the slots for the rear cabanes, after a few cuts and dry fits it was all good. Unfortunately some yellow on the underside got liquefied by the glue and came out so I'll need to do some touching-up....
...except my XF-62 has decided to lighten up on me. This was after some stirring and shaking. Very disappointing. I get paid fortnightly so the fuse will have to wait until I can get some more paint.
« Last Edit: July 02, 2017, 06:33:48 PM by Des »
