Author Topic: Max Immelmann's Fokker E.I 13/15 scratch 1/144  (Read 38115 times)
Re: Max Immelmann's Fokker E.I 13/15 scratch 1/144
« Reply #75 on: August 13, 2017, 04:17:43 AM »
Mind-blowing, spectacular work, Ondra!
« Reply #76 on: August 13, 2017, 04:20:44 AM »
As always My Amigo has it correct! Spectacular indeed!
« Reply #77 on: August 13, 2017, 04:43:51 AM »
I'd somehow missed this one and have just caught up. Beautiful work as always! I just can't get my head around how you create such tiny details without losing them, I have a hard enough time in 1:72!
Offline ondra
« Reply #78 on: August 19, 2017, 10:08:45 PM »
Many thanks for following the build and leaving such generous comments, Andonio, Stephen, Bud, Rick and Ian!
Today I have been experimenting with an alternative method to make the engine cowling, this time using brass sheet. The original intention was to solder the two pieces together, but this turned out to be beyond my skills yet (and obviously I will need a finer soldering iron tip). So I took plan B and glued the two pieces together with photopolymer glue. Hopefully it will be rigid enough.
Ondra
« Reply #79 on: August 19, 2017, 10:10:22 PM »
You never cease to amaze me Ondra! Excellent modeling!
Online Juan
« Reply #80 on: August 19, 2017, 10:37:56 PM »
Agree completely, amazing work, especially at this scale.
« Reply #81 on: August 20, 2017, 06:07:12 AM »
That is a beautiful cowling Ondra - I tink that it will meet your needs admirably.
Offline ondra
« Reply #82 on: August 20, 2017, 10:07:00 PM »
Many thanks, Rick, Juan and Stephen!
Today I drilled the holes for the brass pins and could not resist from dry fitting the wings while praying for the symetry to be correct.
It looks acceptable.
Ondra
« Reply #83 on: August 21, 2017, 04:13:23 AM »
Truly spectacular work, Ondra!  That whole thing is smaller than some of the cockpit components I struggle with in 1/48 scale!
« Reply #84 on: August 21, 2017, 05:08:16 AM »
Looks fabulous with the wings in place!
Offline ondra
« Reply #85 on: August 26, 2017, 09:27:16 PM »
Many thanks for your nice comments, Bud and Rick, they are always highly appreciated!
She started taking the shape of an Eindecker, today I added the cowling and spent a looot of time on filling and sanding. Looks acceptable after all.
Ondra
« Reply #86 on: August 27, 2017, 06:28:30 AM »
Absolutely AWESOME Ondra!
« Reply #87 on: August 27, 2017, 08:11:09 PM »
Another masterpiece, Ondra. Very nice ! The cowling looks fantastic and the ribs still impress me most.
Borsos
Offline ondra
« Reply #88 on: August 28, 2017, 01:00:22 AM »
Many thanks for your encouraging and generous comments, Rick and Borsos!
I wanted to check whether the cowling will be ok, so I sprayed it with black Mr. Surfacer, polished it and gave it a semi translucent coat of Mr. Paint metalizer. So far I have not found a suitable method to render the "swirling" on the cowling to make it look believable in this scale. So for the time being I will just try to create the effect telling "this is not clean polished aluminium", therefore the translucency.
The wings and the tailplanes were given a coat of Drooling Bulldog zinc white and are ready for preshading. As usually I will be using Drooling Bulldog paints for the whole paintjob (fell in love with them). The fuselage and horizontal tailplanes will be painted with a mix of unbleached linen and umbraun lightened with zinc white, for the wings I will probably use the graugrün.
Ondra
« Reply #89 on: August 29, 2017, 06:09:16 AM »
This is work of the highest quality, the more so given the size of the model....unless that hand came from Brobdignag! (Gulliver's Travels).
