Author Topic: 'El Sonora' in 1/72  (Read 16897 times)
Offline Old Man
'El Sonora' in 1/72
« on: May 08, 2017, 02:03:14 AM »
I will be doing a scratch-build of 'El Sonora', the aeroplane which constituted the 'Flota Aérea del Noroeste' operated in 1913 and 1914 by the faction of the Constitutionalistas led by Alvero Obregon during the Mexican Revolution.
The aeroplane is an early product of Glenn Martin, and in fact I only learned of its existence when looking for background information on development of the B-10. I was instantly hooked; everything needed for a 'ripping yarn' of the most classic sort can be found in the tale this machine --- just how it reached Mexico in the first place is only the beginning....
Since it was operated by the force led by the man who emerged from the revolutionary decade as President of Mexico, and one of the men who piloted it went on to a commanding, if checkered, career in the Mexican Air Force, the machine is fairly well known in Mexico, and there is a fair body of photographs to be found. But I have not been able to find any scale drawings, and so will be putting this together rather as the thing was flown, by the seat of my pants, guided by what the photographs of this and other early Glenn Martin products make clear, namely that he cribbed shamelessly from Curtiss.
The trickiest bit of this is the un-cowled motor, so that is where I have started.  In assembling an early Curtiss V-8, I have had to do something resembling precision work on the cylinders, which I don't like to do and try to avoid. My instinct is to employ the old sculptor's maxim, suitably altered for plastic modeling --- take up a piece of plastic and remove everything which is not the part you want. But with the varying rings and steps, this was not going to be a good method for the cylinders of this motor. It took several tries before I got a useable result.
I used 'flying jigs' to get the cylinder pieces uniform. The bits to be assembled were measured against, and in some instances attached to, stock strip pieces of known thickness, and sanded down to match these standard pieces.
 This shows the principle, though it is from an earlier run. From left to right: finished cylinder, dressed cylinder piece on the 'flying jig', raw cylinder piece on the 'flying jig', and raw cylinder assemblies. On this run, the upper step was 2.5 mm, and the lower 0.75 mm. This did not allow for the irreducible thickness of the base ring, and so on the finished item I reduced the lower step to 0.5 mm. This necessitated boring all the way through the lower piece, and fixing the wire pin in the upper piece.
On my first run at this, I made the block too thin. On my second I spaced the cylinders too wide. Further, in both of these, the block was patterned on the OX-5 motor's block. The commercial success of the Curtiss OX-5 motor drowns the earlier V-8 models Curtiss produced, and while the various permutations from the model O on are basically similar, there are a lot of detail differences. OX-5 material can be used as a guide, but by the end-stage, period photographs have to be employed, and given the vagaries of such things, I have had to employ a certain amount of creative gizmology in here.
When I began the final run, I started by making the cylinder mount. It is hollow, with a base piece of 15 thou card, 11mm long and 5mm wide, a spine piece 2.5mm high down the center, and side pieces tented in. Shaved discs of 2 mm rod are attached.
Here are the new cylinders with the some of the receiving holes bored in the cylinder base.
Here are the cylinders attached.
Here is the cylinder assembly mounted to the second OX-5 pattern block. The block is 3 mm wide, made of three pieces of 1 mm sheet laminated together.
Here is the start of detailing. A further disc of shaved 2 mm rod tops each cylinder, with a head piece of slightly thinned 2 mm rod atop this. Curtiss cylinders were held down by four long bolts and an 'X' fitting over the cap. The block has been re-shaped to the earlier pattern.
Here are the fuel feeds and rocker arms in.
Here is the current state, with water lines and exhaust ports in, as well as sundry other 'works' shown in photographs....
Further work on this motor must await mounting on its trestle above the lower wing, so it can tie in with the radiator and fuel tanks and carburetor and wing assembly.
In keeping with the policy of getting all the trickiest bits out o the way first, however, the next step in this will be producing three bar-spoke wheels....
Online Juan
Re: 'El Sonora' in 1/72
« Reply #1 on: May 08, 2017, 02:12:00 AM »
Wow, your scratch building at this scale is amazing.  Really looking forward to your progress.
Offline ondra
« Reply #2 on: May 08, 2017, 02:22:02 AM »
My hat is off to your scratch building skills, sir, this is pure pleasure to look at!
Ondra
« Reply #3 on: May 08, 2017, 04:42:08 AM »
This should be fun!
 That is beautiful work on the engine. Having just completed 4 scratchbuilt engines for my Muromets I can fully appreciate what went into this!
Online RAGIII
« Reply #4 on: May 08, 2017, 05:48:34 AM »
That is an amazing piece of scratch building and the results are one beautiful engine!
« Reply #5 on: May 08, 2017, 06:27:48 AM »
Fascinating subject and amazing work, this is going to be a great one to follow!
« Reply #6 on: May 08, 2017, 07:08:26 AM »
Big Ditto to all the above
« Reply #7 on: May 08, 2017, 08:20:01 AM »
Amazing work on the engine, your scratch building skills in 1:72 scale are amazing, I had difficulties scratching the same engine in 1:32 scale for my Curtis Hydroaeroplane. I will be following your build closely as I love this early type of aeroplane, excellent work so far.
« Reply #8 on: May 08, 2017, 08:35:05 AM »
First class scratch building of a quality we have come to expect from you. Just incredible how you manage not only to get in all that detail, but to be consistent with it. Having had considerable experience scratch building engines in this scale I can only write that I truly admire your skill….and just wish I had more of it!
« Reply #9 on: May 08, 2017, 12:06:27 PM »
 Old Man,
Scratch building is a challenge to itself my old friend. But doing so in 1/72 scale requires a large dose of talent along with equal portions of skilled wizardry. I have no doubts that you have an endless supply of both. Well Done my old friend,keep up the excellence!
« Reply #10 on: May 08, 2017, 02:42:24 PM »
Unbelievable! This is great. I will watch carefully and try to learn from your skills
« Reply #11 on: May 08, 2017, 11:02:32 PM »
Another great build, OM.  The back story is interesting and that engine looks fantastic!  Very well done.
Offline Old Man
« Reply #12 on: May 10, 2017, 02:34:22 AM »
Thank you, Gentlemen.
I appreciate the kind words.
I will be getting back to the bench this evening. I expect to take a solid run at the spoke wheels before the weekend.
« Reply #13 on: May 10, 2017, 03:39:20 AM »
Spectacular engine, OM!  Can't wait to see what else you have in store for us!
« Reply #14 on: May 17, 2017, 12:46:15 AM »
great start on the engine old man looking forward to seeing the rest of this curtiss machine come together.
