Author Topic: 1/32 Morane Saulnier L - scratching an itch  (Read 33603 times)
Re: 1/32 Morane Saulnier L - scratching an itch
« Reply #30 on: April 06, 2017, 04:13:06 AM »
Absolutely. You can do it after sunset - depends on your neighborhood.
Borsos
Offline Syd Solo
« Reply #31 on: April 06, 2017, 07:39:59 PM »
When I am finished, am I allowed to run around the house with it going brrrr-brrr-brrr?
what about ratatta-ratatta-tat?
Admire your building skills. Perhaps you are channeling Harry. 😉
Syd
Offline RLWP
  • Bodger
« Reply #32 on: April 07, 2017, 06:52:41 PM »
I have finished the access panels:
And now I have taken the picture, I notice I have missed off a bit of strip!
Next up is the internal rigging wires, and I'm not entirely sure how I am going to do them
Offline xan
« Reply #33 on: April 07, 2017, 11:06:45 PM »
wonderful work
acces panels are just perfects!
Xan
Offline RLWP
  • Bodger
« Reply #34 on: April 08, 2017, 06:52:32 PM »
I had a complicated plan for the internal wires, and ended up using a simple plan:
I was going to use two complicated zig-zag bits of copper wire. In the end, these are separate bits of copper wire positioned and secured with a drop of superglue
Good enough for an illusion
« Reply #35 on: April 09, 2017, 02:06:58 AM »
Absolutely! It's very convincing. The more I look at your build the more I want a Morane Saulnier L too...
Can't wait for the next update
Borsos
« Reply #36 on: April 09, 2017, 03:56:59 AM »
Fust enough to give an impression….not enough to make a complete mess!
Offline RLWP
  • Bodger
« Reply #37 on: April 09, 2017, 05:49:40 AM »
Exactly. You have described the compromise to perfection
« Reply #38 on: April 12, 2017, 02:52:03 AM »
Looking really good, Richard! I'm enjoying the pictures and the solutions to the build challenges! Great Modelling! Marc
Offline RLWP
  • Bodger
« Reply #39 on: April 13, 2017, 06:41:06 PM »
Small steps
Top left is the WnW engine with a tidied up Academy prop from the scrap box.
Top right is the rudder - a bit of shaped balsa sandwiched between a couple of sheets of styrene. The grey bits are filler from where clothes pegs dented the styrene during bodging
Bottom are the joystick and rudder bar. There is a strong element of creativity going on here as I'm not sure what the originals looked like. Still, Harry Woodman seems clear that completing a model is better than obsessing over unknown details. I'm trying to follow that
« Reply #40 on: April 13, 2017, 07:21:21 PM »
Coming along beautifully Richard, the little details make all the difference.
Offline RLWP
  • Bodger
« Reply #41 on: April 13, 2017, 10:11:15 PM »
Thank you, Des. These bits actually worry me - I know that I can get stuck in the middle of these fiddly bits and not finish a project
On the subject of internal bits and bobs, I want to equip this 'plane with a spark transmitter. I believe this is the 'right' unit:
http://blogs.mhs.ox.ac.uk/innovatingincombat/tag/wireless/
In addition, I think there would have been an aerial on a reel, a 6V battery and a key - perhaps fireproof. Does anyone have illustrations of the battery and key?
Offline RLWP
  • Bodger
« Reply #42 on: April 14, 2017, 03:23:51 AM »
Yes, I was trying to decide between 'battery' and 'accumulator'. I went for battery as I thought more people would recognise the term
« Reply #43 on: April 14, 2017, 03:33:51 AM »
Whatever term you use you are making an excellent replica of this machine. In this scale these details really matter but equally very few people will know exactly what different components looked like.
Offline RLWP
  • Bodger
« Reply #44 on: April 14, 2017, 05:07:26 AM »
WNW's website has a lot of pics.
Check those out as I found some of the details for other builds there.
Indeed. For instance, the RE.8 has the Stirling spark transmitter, aerial reel and accumulator as optional accessories and they are shown in the instructions. What I can't find is a picture of the actual accumulator, or of the Stirling set installed.
It isn't really surprising. The accumulator would need recharging, and apparently the spark gap transmitters also needed servicing after every flight
