WW1 Aircraft Information/Questions
Pfalz DIIIa and DXII serial number size
Topic: Pfalz DIIIa and DXII serial number size (Read 1142 times)
jeroen_R90S
March 09, 2017, 01:13:30 AM »
(probably) quick question... are the fuselage, strut and rudder serial numbers the same size on the WNW Pfalz DIIIa and DXII decal sheets? I have the DIIIa but in a far away future I might need some extra Pfalz numbers from the DXII sheet for a specific machine I have in mind and I'd be curious if they are the same size, or, at least, close.
Thanks!
Jeroen
mike in calif
Full Member
Re: Pfalz DIIIa and DXII serial number size
March 15, 2017, 08:26:58 AM »
wingstrut, DXII=.050 wingstrut, DIIIa= .053
fuselage, DXII= .130 fuselage DIIIa =.130
The DXII has no kit examples with serials on the rudder, and the DIIIa only two, which appear to be the same size.
jeroen_R90S
March 15, 2017, 08:45:19 PM »
Many thanks for taking the effort of making actual measurements!
The strut numbers seem close enough to use. I've had contact with Dave J to see if I can obtail a kit sheet or just the numbers as I'm not
that
interested in the D.XII.
I'll need only the "00" from 2600/18, the rest I can puzzle together from what's there in the D.IIIa kit.
Thanks again!
Jeroen
