Thanks Larry!
___________________
So, I'm moving along with decaling this thing. For anyone who hasn't used them, here's some stuff to look out for when working with the Ronny Barr decals (I assume it's the same with the other sheets Uschi offers).
The decals are patterned in such a way that it's like a repetition of the same wood grain over and over. In general, it's smart to be on the lookout for things that pop out as repetition on your model, so one thing that's smart to do is to flip them upside down and not always cut consecutive panels from the same orientation. The grain will still be in the same direction, etc. The things to look out for that actually strike the eye as especially repetitive are whirls and umber-coloured dots.
Here's an example where I was being too clever by half. When I did the nail holes in my Alby, I taped the lines with fine-line tape and then tried to follow them with the rivet tool, not always with success, but the long line on the port side had a slight wobble near the cockpit that I didn't like, so I tried to bury the thing in one of the more active dark patterns of one of Uschi's decals. I was successful actually, but didn't realize that I had a repeat pattern that is impossible to unsee once you see it.
Without visual aids:
Note my high-tech tool, lol. It's just a needle stuck into a piece of sprue that I drilled. The sprue has led a double life and upgraded its duties from paint stirrer to poking tool. Seriously one of the most useful tools I have though.
With visual aids:
Ugh, same orientation too. Again, can't be unseen.
Another, larger shot:
So what to do? I don't want to try to lift the decal and toss it. But I have options. The two that seem most obvious: I have a ton of Windsor & Newton oils from when I once fancied myself a painter, so I can try to match hue and value and simply subtly cover one of the dots with a reddish or ochre colour blended in, or for that matter I can add more dots and obfuscate the sameness of the pattern by making it more dotty. I'm in the middle of deciding which, but will post the result when I'm done.
