The parts of for the flight compass will come on the sprue like this. Red parts are waste:
Start by removing the cup with a fine tooth razor saw:
Next, drill out the two holes in the side of the cup with a .3mm bit:
Now, with the cradle still attached to the sprue, drill out the hole at the end of each arm with a .3mm bit:
Remove the cradle. Carefully cut the ends away first, then the base:
Trim away the excess sprue material as shown:
With the ring still attached to the remaining sprue, drill out the 4 holes clear thru the ring with a .3mm bit. Then carefully remove the ring from the sprue:
Attach the cup inside the ring with two pins made from .25mm wire:
Attach the cup and ring assembly to the cradle with another pair of wire pins, also .25mm wire:
Beneath the cradle there was a rod where magnets were attached to correct the compass. This can be made from .4 or .5mm brass tube:
Finish the compass with decals from the spare box, or print your own face.
Single compass:
https://www.shapeways.com/product/BSKEAM2WC/ww1-german-aircraft-compasspair of compasses (save a few bucks):
https://www.shapeways.com/product/LPXT62DW6/ww1-german-aircraft-compass-pairThe pair is also now available in 1/28:
https://www.shapeways.com/product/XC8G5UMNY/1-28-german-flight-compass-pair
