Under Construction
RAF SE.5a Polish (1/32, mostly WNW)
Pages:
3
4
5
Topic: RAF SE.5a Polish (1/32, mostly WNW) (Read 17289 times)
steveb
Full Member
Re: RAF SE.5a Polish (1/32, mostly WNW)
Reply #15 on:
January 11, 2017, 02:05:05 PM »
Yes, as others said, looking forward to more updates!
PrzemoL
Reply #16 on:
January 15, 2017, 08:39:31 AM »
Thanks, everybody for your kind words.
The interior bits are now ready for the assembly. Besides the earlier shown mods I have also added two pulleys for the aileron cables and run the elevator, rudder and tailskid controls. And the seatbelts are from HGW.
Because of the cockpit breakdown with rudder bar sitting on a separate lower wing centre piece, the only way to tension the rudder cables is to run them along the entire fuselage to the openings at the tail. I realised it late and had to lengthen them using tube bits. Now the cables are led through their holes and the assembly of the fuselage can start. And the loosely flinging rudder bar will be attached to its socket some time later, when the lower wing jumps in.
Last Edit: October 12, 2017, 09:36:18 PM by PrzemoL
Adam
Reply #17 on:
January 15, 2017, 09:23:02 AM »
Nice to see yours next airplane with white and red checkers.
With great interest I will be watching how is created another masterpiece.
Adam.
Love the self
Reply #18 on:
January 16, 2017, 12:38:05 AM »
Coming along very well so far Prze . Nice details on the control lines running off the column .
Reply #19 on:
January 16, 2017, 01:14:29 AM »
Extremely well done control rigging. Adding the pulleys was brilliant work!
Last Edit: January 23, 2017, 03:57:53 AM by RAGIII
lone modeller
Reply #20 on:
January 16, 2017, 03:36:12 AM »
As usual no detail is too small to miss your eyes. Brilliant work.
steveb
Full Member
Reply #21 on:
January 16, 2017, 04:47:21 AM »
Fantastic work on all the colors & textures! A pleasure to see.
PrzemoL
Reply #22 on:
January 16, 2017, 08:19:46 AM »
Cheers, gals and guys.
Some more progress on the assembly. Fuse halves together and the lower wing on, which allowed to mount the rudder bar.
And with the cockpit top decking, which will indeed, as some of you reported, require some filling along the seams. Pressing it home together with the ammo boxes attached and the cables for throttle control passing through the hole in the side shelf and going somewhere to the engine required some tweaking but was successful.
Now not much can be seen fromthe cockpit in photos, one has really to look into the openings.
Last Edit: October 12, 2017, 09:37:14 PM by PrzemoL
Juan
All gave some, some gave all.
Reply #23 on:
January 16, 2017, 08:59:03 AM »
Looking really sharp, love what you have accomplished so far.
ALBATROS1234
Reply #24 on:
January 17, 2017, 01:43:53 AM »
gorgeous se5a przemol.
dr 1 ace
Reply #25 on:
January 17, 2017, 07:49:30 AM »
Another Masterpiece in the making !!!
Reply #26 on:
January 17, 2017, 08:43:07 AM »
Quote from: dr 1 ace on January 17, 2017, 07:49:30 AM
I agree with Ed!
aliluke
Reply #27 on:
January 22, 2017, 06:36:40 PM »
Your work is so crisp and clean even under the microscope. Amazing! Will be following.
Best regards
Alistair
Juan
Reply #28 on:
January 23, 2017, 05:17:31 AM »
She is truly looking beautiful.
xmald
Reply #29 on:
January 26, 2017, 06:20:15 AM »
Crisp, clean and perfect as always Przemo!
Best regards
Filip
Pages:
3
4
5
Under Construction
