And it goes on. On the pictures of the inside of the hull you can see that there is not much to see in Roden. The ammo drum racks I have already supplemented. What was missing now was the tension. Since one can see from the top as well as from below into the inside of the trunk, something had to happen. And that's what happened.
The wires are made of 0.2 mm (01/64in) copper wire.
And if you now think I'm a little crazy, yes, that's me.
A small problem with the tension wires on the inside, however, I have. I just found this randomly on the Internet this photo. It's from the "Popular Mechanics" Magazine October 1917.
Wikimedia)
As can be seen in the drawing, the lower opening was covered by a tunnel. And, of course, you can not see the tension cables in the rear area. What do you all mean? Should one stay with the original (tunnel), or do without it, so that one can see the tension wires?
Jürgen
