Author Topic: LVG C.VI, Pegasus 1/72  (Read 28298 times)
Offline Ian from Doncaster
Re: LVG C.VI, Pegasus 1/72
« Reply #30 on: November 16, 2016, 11:35:39 PM »
Great work in 1:72 Wolf!!
I would be delighted to put together an engine like that in 1:48, never mind 1:72 - and you even did ignition wires!
The tip to use WNW instructions for a smaller scale model is very useful - for example some kits in the smaller scales don't come with rigging diagrams, whereas the WNW kits do.  Of course, we can all do our own research, too..
I am really looking forward to the surface finish on the fuselage of this model, and the seat/tank assembly looks great too.
« Reply #31 on: November 17, 2016, 05:32:38 AM »
 Wolf,
Now that some very impressive modeling my friend. I'm truly amazed at the detail you've added to date. Keep up the excellence and keep those updates coming.
Offline Wolf
« Reply #32 on: November 18, 2016, 01:44:02 AM »
Just a minor update: I primed the fuselage interior mit Gunze yellow sand and shadowed it a little bit with Gunze Tan.
After the paint has dryed, I applied oil paint (burnt sienna and amber).
This was subsequent removed with a medium stiff flat brush until I was satisfied with the result. I think, this is the common known way to replicate wood grain with little work
« Last Edit: December 01, 2017, 12:17:40 AM by Wolf »
« Reply #33 on: November 18, 2016, 02:10:32 AM »
Nicely done wood grain effect!
Offline jeroen_R90S
« Reply #34 on: November 20, 2016, 06:46:01 AM »
Looking good! I've built some Roden kits so far, and only one Pegasus, and found the Pegasus the most challenging of them.
Offline Wolf
« Reply #35 on: November 28, 2016, 06:25:46 AM »
I started to assemble the cockpit. I started with the scratch build of a little control cabinet situated on the left side. Then, after the floor was glued into place, I added the fuel tank, the control stick and the pilots seat.
« Last Edit: December 01, 2017, 12:18:20 AM by Wolf »
« Reply #36 on: November 28, 2016, 06:41:21 AM »
Great progress Wolf, like what you have done so far.  Looking forward to your next post.
« Reply #37 on: November 28, 2016, 08:49:47 AM »
Very nice! The wood tones look wonderful.
« Reply #38 on: November 28, 2016, 09:52:09 AM »
Really nice work with the engine, fuel tank and seat, the wood colours look excellent, great work so far.
« Reply #39 on: November 28, 2016, 06:59:00 PM »
Cool, the wood and the leather of the seat look great.
manni
« Reply #40 on: November 29, 2016, 01:24:10 AM »
Excellent! Looking forward to more!!
« Reply #41 on: November 29, 2016, 06:22:08 AM »
This is looking beautiful, Wolf, with some great attention to detail and wonderful colours - I like it a lot! Regards, Marc
WarrenD
« Reply #42 on: November 30, 2016, 10:22:42 AM »
Really great work!
Offline TobyCoulson
« Reply #43 on: November 30, 2016, 08:39:41 PM »
Great detail the the wood effect is superb.
Offline Wolf
« Reply #44 on: December 05, 2016, 03:29:33 AM »
Thanks a lot, Gentlemen.
I have finished my work on detailing the cockpit. The engine is also in its place.
Before I started my work on the interior, I did some dryfitting. This revealed that there are some gaps to be expected in the cockpit area. So, before I will glue both halves together, I added some styrene sheet at the critical points. This will hopefully minimize some work later.
I also added some sheet to help bringing the engine to the right position.
« Last Edit: December 01, 2017, 12:21:22 AM by Wolf »
