So, another significant bit of progress achieved on this project. The aircraft is complete; now it's time to get at the display base and the accessories to create some form of Diorama. I've taken some quick photos of the aircraft for the interim. Once It's on the display base I'll take more for "Completed Models."
The rigging, and there's not a lot on this bird, was completed with Modelkasten elastic thread, stainless guitar wire for the aileron cables between upper and lower wing, and Bob's Buckles. The float support wires were done float to float as opposed to between the float spars as recommended by, I believe, Przemol on his Build.
This is the front strut joint on the left side that had a 1-2mm extension added as did the rear one, the only solution I could determine for the fit problem I was struggling with earlier.
The exhaust assembly was added at the very end to prevent accidental removal.......
.....and the same for the prop and the GasPatch Parabellum.
and here she is in total.......
Now it's time to clean up the bench and get started on the "base work".
