Hello friends,
thank you very much for your kind comments
This diorama build displays a dazzling array of superior and enviable modelling skills. One question Borsos: are you mortal?
Syd
Thanks Syd, just too mortal. I see that every time when I see my kids grew up so fast and me getting older and older... One day when I got up after having had a good evening with the old friends I had to realize that some parts of my body (head, stomach) were already dead....
Fabulous work Borsos, absolutely stunning! Since you are going to have the crew lying out on the ground, don't forget to position everything in a way that would either leave access to pull them out, or show that the parts had been moved to get at the pilot!
Absolutely, Ian, thanks for the hint. Yes I had planned to show the crashed seat that was removed from the inside with the pilot. As the certain design of the C II seat is unknown I had the choice between a seat like it was installed in the later LVG two seaters (like the C VI) or a seat like it was installed in the LVG B II. In the end I went with a LVG B II seat whose design I took from the great Krakow aviation museum website.
Now it is slowly getting finished. Some details need painting and I have to start rigging (which is like bridling a dead horse somehow)
... the radiator is plastic mesh sandwiched between some plastic sheet sanded to shape.
Thank you!
Borsos
