Author Topic: 1/48 Halberstadt Cl.IV with pilot and ground crew  (Read 7489 times)
guitarlute101
« on: July 19, 2016, 09:49:05 AM »
Hi,
I'm in with a !/48 Halberstadt Cl.IV with pilot and ground crew and other bits and pieces.
Re: 1/48 Halberstadt Cl.IV with pilot and ground crew
« Reply #1 on: July 19, 2016, 09:57:19 AM »
Welcome to the GB Mark, I'm looking forward to seeing you make a start on this build.
guitarlute101
« Reply #2 on: July 19, 2016, 10:22:07 AM »
Thanks Des!
« Reply #3 on: July 20, 2016, 02:46:03 AM »
That looks very interesting - one I will be following with pleasure. Good luck with the build Mark.
« Reply #4 on: July 20, 2016, 04:17:41 AM »
This Kit is Great. I can't wait to see it built!
« Reply #5 on: July 20, 2016, 04:30:32 AM »
This is a great kit, Mark.  I know you'll do a spectacular job on it.  If I remember correctly, you built the Mirage version, right? (or was that me? ???)  At any rate, I know that you had built the Mirage Cl.II with stunning results, so you know your way around the type.  Looking forward to following along.
Offline stefanbuss
« Reply #6 on: July 20, 2016, 08:28:40 PM »
One of my favourite aircraft. Looking forward and following closely. It will be interesting to see how those Eduard crew will come out.
Stefan
guitarlute101
« Reply #7 on: January 08, 2017, 12:37:26 PM »
A little bit of a late start but here we go...
I will be doing this profile from Pheon's Halberstadt sheet......
I decided to redo the interior structure because the kit detail is a little soft........
And finally, I separated the ailerons from the wing........
« Reply #8 on: January 08, 2017, 01:11:11 PM »
Excellent choice of schemes, Mark!  If I remember correctly, this will go quite well with you Cl.II.  As I said back in July  ;) , I look forward to following along on this one.
« Reply #9 on: January 08, 2017, 05:19:21 PM »
Good choice, Schlasta 26b! an unit, that originally came from Fürth, a city in my neighbourhood. I love the flames  :)
Borsos
« Reply #10 on: January 09, 2017, 12:24:04 AM »
As stated previously, this should be a very colorful diorama.  Look forward to your work on this one.
guitarlute101
« Reply #11 on: January 09, 2017, 03:19:07 AM »
Many thanks guys, it's nice to have some bench time again.
I've finished up the fuselage interior bracing and added some shims and straightened up the wings and ailerons.................
Thanks for looking in!
guitarlute101
« Reply #12 on: January 09, 2017, 05:29:09 AM »
Working on the foot guards for the control lines in the observers pit.
I liberated a pie pan from the refrigerator lol......
Just a little cutting and shaping......................
And viola..........
« Reply #13 on: January 09, 2017, 10:47:30 AM »
Nice job Mark  :) Love your chosen scheme  ;)
« Reply #14 on: January 09, 2017, 09:44:02 PM »
Great start and, ask Terri mentioned, a beautiful scheme.
