Author Topic: Aviattic 1:32 Marienfelde Lorry and Driver  (Read 12618 times)
Offline jknaus
Re: Aviattic 1:32 Marienfelde Lorry and Driver
« Reply #15 on: June 28, 2016, 02:02:41 AM »
Awesome work on this kit. I think I'll pull mine out and give it another look over. Will follow your build with interest.
James
« Reply #16 on: June 28, 2016, 08:20:13 AM »
You are doing a superb job with this build James, the weathering really brings the truck to life and the figure is absolutely awesome, looking forward to seeing the diorama you will be putting this truck in.
Offline FarEast
« Reply #17 on: June 28, 2016, 04:38:58 PM »
Quote from Edo......
"very beautiful build indeed!
I am looking forward for what it will turn out in the end..."
  ................. and so am I!
   A Gotha, a Lorry, some figures and "action", and a very talented Builder, this is going to be a pleasure to follow!
Lance, there maybe two Gotha! But undecided yet :D
Offline FarEast
« Reply #18 on: June 28, 2016, 04:40:44 PM »
In the meanwhile: I saw you use a Dremmel like cutter... how do you use it? Whaen I use mine il melts plastic and it does not cut through it...
thank you
ciao
edo
Well on a resin kit there is no issue of over heating I think I had the settings on the Dremel to medium speed and just worked in small sections at a time. Also you need to make sure you have the correct tooling for the job.
Offline FarEast
« Reply #19 on: June 28, 2016, 04:41:59 PM »
James
James many thanks, in more ways than one! Your help is always very much appreciated!
Offline FarEast
« Reply #20 on: June 28, 2016, 04:44:49 PM »
Des I think this is my biggest project to date.... I'm actually worried I bit off more than I can chew, however I'm going about this how I do my usual builds. Each individual part is its own project that is also broken down in to sub-projects. Stage 1 of the cab is done, stage 2 is the chassis and then stage 3 is the flatbed.
I have to say the kit is really well made and I'm loving how all the extra detailing is already supplied in the box for you - it really is a multimedia kit.
« Reply #21 on: June 28, 2016, 08:39:28 PM »
Great job on the lorry, James.  I am looking forward to seeing
the diorama it will be a part of.  Brilliant work on the figure
as well, my friend!
« Reply #22 on: June 28, 2016, 11:58:34 PM »
James,
    Two Gothas?!?! :o Now it's double the pleasure to follow along! I'll be watching with great interest.
Offline Russell
« Reply #23 on: June 29, 2016, 12:04:24 AM »
OK I don't even have to think about you building a brace of Gotha as they will be superb - what I'd like to know is how will you display them plus a lorry? :o  ;)
« Reply #24 on: June 29, 2016, 02:33:24 AM »
Goodness me, I feel so fortunate to be part of a forum where "top-notch" builders share with us their work on exquisite products, such as those emanating from Richard and the team at Aviattic.
Offline FarEast
« Reply #25 on: July 04, 2016, 03:03:53 PM »
The flatbed was the next on the list and I decided to heavily weather the wood.
From here I only applied oils and left to dry, no translucent orange or varnish just the flat oils. Once it has fully cured I will give it a mat finish.
Next up were the wheels - After spraying the rubber tires Nato black and then dry-brushing with a lighter grey I masked them off with Tamiya flexible masking tape. This stuff is great and you can move it around so finely that I was able to leave the rim free.
With the tape removed I applied several washes to get the effect I needed and then left to dry. There was very little seepage from the washes and those were easily delt with with a cotton bud.
Staying with the cab It was time to shape the front wheel fenders - to get the curve I used and empty Tamiya paint pot.
The underside of the Lorry received a very liberal coating of AK Interactive Engine oil.
Small parts such as the side lamps and the horn where assembled and painted before being attached to the cab.
« Reply #26 on: July 04, 2016, 03:48:05 PM »
Very nice done! I like your "sparkling" technique of preshading. Top work,
Offline FarEast
« Reply #27 on: July 04, 2016, 03:53:43 PM »
Thank you Manni,
Easiest way to replicate deep oil splattering and other spillages - just load up the brush with thick paint and let the airbrush choke :D
« Reply #28 on: July 04, 2016, 06:29:40 PM »
Great build! The contrast between the warm wood tones and the feldgrau are just beautifull! I follow your topic with huge pleasure.
Borsos
Offline Russell
« Reply #29 on: July 04, 2016, 08:08:13 PM »
That was fast!  :o
Wonderful as well  :D
Russell
