Author Topic: Lindberg 1911 Avro Biplane 1/48th  (Read 35827 times)
Re: Lindberg 1911 Avro Biplane 1/48th
« Reply #60 on: July 27, 2016, 07:25:44 PM »
Hi Dan, great work on the rigging, I am not sure I understood what the anti-drag wires are...
Moreover it will be _very_ interesting for me to watch how-to make the spoke wheels!
Antonio
« Reply #61 on: July 27, 2016, 08:55:11 PM »
Excellent work with the rigging Dan, it all looks good to me.
« Reply #62 on: July 28, 2016, 02:47:11 AM »
Dan,
I found on the drawings that I used that there were two sets of anti-drag wires form the top of the middle struts to the frame at the bottom of the fuselage where they were attached one and two bays behind the pilot's bay. There were two wires from the top of the rudder post which went to the leading corner of the horizontal tail unit and to the elevator hinge. Apart from that my model appears to be very similar to yours: except that yours looks better!
Andonio: anti-drag wires were wires which ran from the front struts to either the front of the nose or in this case to the undercarriage legs ahead of the wing leading edge. There were also wires from the rear struts also to the fuselage. There purpose was to even the stresses on the wings and transmit some of the drag forces on the wings to the fuselage structure. In effect they helped to stop the wings from bending backwards as they passed through the air.
Offline NinetythirdLiberator
« Reply #63 on: July 28, 2016, 05:51:44 AM »
Thanks for the comments, All...
And Stephen...your description really helps and I'm pretty close with my drag wires.  They do seem to match basically what you said.  I'll add some stuff to the tail, though!  Thanks for that info!
And where is this horrible SCRATCH build, 1/72nd Avro of which you speak?  ;) ;)  I'd love to take a look. I bet it's awesome.
More soon...Dan
« Reply #64 on: July 28, 2016, 05:11:33 PM »
Thanks Stephen!
« Reply #65 on: July 29, 2016, 03:41:08 AM »
And Stephen... where is this horrible SCRATCH build, 1/72nd Avro of which you speak?  ;) ;)  I'd love to take a look. I bet it's awesome.
More soon…Dan
Dan,
 The build thread is under scratch builds page 2: there are also photos in the completed models section page 8.
Stephen
« Reply #66 on: July 29, 2016, 06:51:44 AM »
Dan,
    The rigging has really brought it all together, it's one very impressive Model, and I'm looking forward to watching your work on those wire wheels!
Lovely work!
« Reply #67 on: August 01, 2016, 03:43:17 PM »
Wow, looks awsome. It is jaw dropping what you have made of this ols kit.
« Reply #68 on: September 20, 2016, 01:58:52 PM »
Wow...it's been awhile!   :o
I have been super busy but this AVRO has not been forgotten.  I started playing around with making spoke wheels and I think I got acceptable results.  I made one and now have 3 more to do!  I hope they get better as I go.  One thing is for sure...they look worlds better than what came in the kit.  The pictures tell the story but some background includes I used this method before on some flying models but wasn't sure it would work in this small size.  Worked great!  Second:  I've been building some paper card models recently and have found that paper and glue are amazing and surprisingly strong!  So the hubs, wheels and tires are all made of thick card stock paper layers (I think I used 110 lb stock).  The spokes started as fine thread which was a disaster!  Then I simply used small pieces of invisible mending thread and just glued them around the hub and rim at the same time.
Anyway, see what you think!  I want this guy done for a model show this coming Saturday so I'll see if I can get the other wheels done ASAP.  Next post will be in the finished construction section!!   8)
On to the photos:
Left: double thickness wheels, center are paper rolled hubs and right are the tires...two to sandwich each wheel.
Jig:
In Use:
Disaster Below!
Acceptable:
Clamping:
Compare:
Finished:
Not too darn shabby for home made spoke wheels!  More practice in in order like more rounding of the tires but...
Thanks for looking at this long post,
Dan
« Reply #69 on: September 20, 2016, 02:54:41 PM »
Excellent work with the spoked wheels Dan, they are a difficult thing to make but you have done a superb job.
« Reply #70 on: September 20, 2016, 04:12:25 PM »
I think, for the first attempt the wheel looks very nice.
« Reply #71 on: September 20, 2016, 04:59:05 PM »
Indeed an excellent result Dan!
« Reply #72 on: September 20, 2016, 11:42:31 PM »
Outstanding work on the spoked wheels Dan! They look great!
« Reply #73 on: September 21, 2016, 12:38:09 AM »
I'm with my amigo on this, Dan!  Rick plucked the exact words right outta my brain!
Offline eindecker
    • Models In Scale
« Reply #74 on: September 21, 2016, 12:41:37 PM »
I'm impressed! Using thick card stock is a novel notion, looks like it worked very well. Thanks for posting your method.
Michael Scott
