Thank you very much! I'm happy that you like it
Today I got the Workingplace of the pilot busier. The devices are upgraded kitparts using the PE fret or scratchbuilt:
I can say now I fell definitely in love with that project and the bigger scale...
The metal rod for the air speed indicator and the rear mounts of the MGs is a prominent feature of all Albatros scouts. Roden has added two small blocks on each end and wants you to glue the rod under the top stringer. that's what I did first. Testfitting the MG's (Gaspatch already delivered the proper MGs, the Spandau 08):
It is not just the angle of the photo: The MGs look upward as if it were Boelkes Fokker E IV...
The simple solution is to cut the blocks...
... and to glue the rod between the two upper stringers. Now the MGs fit like they should
And on the real thing this installation is the correct one anyway - between, not under the top stringers.
Thank you
Borsos
