Author Topic: Edward Mannock's S.E.5a 1/144 scratch  (Read 39616 times)
Offline ondra
« on: March 26, 2016, 03:41:02 AM »
Hello everybody,
my next build will be Mannock's S.E.5a he flew at 74. Squadron. Almost no photos are available for this particular machine which does not make me worried. :) At least I have more space for "artistic licence".
Today I just started working on the wings and fuselage. Can't wait to use the Drooling Bulldog PC 10 and linen edition paints on this one. :)
Ondra
Re: Edward Mannock's S.E.5a 1/144 scratch
« Reply #1 on: March 26, 2016, 04:34:36 AM »
this looks gret already ,the shaped look very accurate. much respect to you scratch building at these small sizes. its a whole different set of skills than most of us around here are used to.
« Reply #2 on: March 26, 2016, 07:04:46 AM »
You have made an excellent start on this scratch build Ondra, I will be following along closely.
Online RAGIII
« Reply #3 on: March 26, 2016, 07:46:22 AM »
Well Ondra, as always an amazing start to one of your tiny scratch builds! I am looking forward to your progress!
Offline ondra
« Reply #4 on: March 30, 2016, 03:17:55 AM »
Many thanks for looking in and following, Scott, Des and Rick!
Just a slight progress on the fuselage.
For the S.E.5a fuselage one I would like to try a new method which should allow me (perhaps) achieving a better accuracy and final fit of the particular elements. The cover for the cockpit I would like to make using a method similar to making canopies (unfortunately I am not able to find the correct expression for this method...).
Ondra
« Reply #5 on: March 30, 2016, 03:35:17 AM »
Brilliant work, Ondra!  You never cease to astonish me with your craftsmanship in this minute scale.
Offline Culi
« Reply #6 on: March 30, 2016, 06:59:23 AM »
Great job. I am sure it will be another masterpiece.
Looking forward next steps.
Aleksandar - Culi
The process meters...  therefore so much models are stuck between start and finish
« Reply #7 on: March 30, 2016, 07:27:36 AM »
You are making great progress with this build Ondra, what you have done so far is excellent.
Offline BigBlue
« Reply #8 on: March 30, 2016, 09:16:45 AM »
I am amazed at what you are able to achieve Ondra.  The fact that it is 144th scale just makes it mind boggling!
« Reply #9 on: March 30, 2016, 10:17:18 AM »
You really are a master of microscopic aeroplanes, Ondra!  Good start on
the SE5, my friend.
Offline TobyCoulson
« Reply #10 on: March 30, 2016, 07:35:45 PM »
Absolutely astonishing work especially in that scale. You have great modelling skills.
« Reply #11 on: March 30, 2016, 08:52:54 PM »
The blue has thrown me a bit Ondra.  What material are you
using for the construction?
Offline ondra
« Reply #12 on: March 30, 2016, 11:08:05 PM »
Thank you all for your encouraging moments!
to Ernie: I use plastic sheets used for information shields (like "no entry" or "no trespassing"), it is the same material as Evergreen sheets, just slightly harder and much cheaper. I bought 8 sheets (A4 format) about four years ago, this stock seems to be sufficient for about 40 model in my scale. :)
Ondra
« Reply #13 on: April 01, 2016, 08:45:26 AM »
Your scratch build is very great like your others Ondra.
« Reply #14 on: April 01, 2016, 09:34:51 PM »
Ondra
What a great tip, Ondra!  Thanks, my friend. :D
