Under Construction
Scratch builds
Maurice Farman MF 11 no. 1338, MF 2, April 1916, Verdun-Front
Pages:
3
Topic: Maurice Farman MF 11 no. 1338, MF 2, April 1916, Verdun-Front (Read 7880 times)
Edo
Re: Maurice Farman MF 11 no. 1338, MF 2, April 1916, Verdun-Front
Reply #30 on:
March 22, 2016, 10:35:41 PM »
Het borsos!
I just discovered this post: you are doing magic!!
Wow!
ciao
edo
Reply #31 on:
March 23, 2016, 11:11:00 PM »
Your wings are beautifully done. Too bad about the slight error! Is there a way to use what you have and make the correction or do you need to make completely new wings?
Last Edit: March 25, 2016, 12:14:29 AM by RAGIII
Thumbs up
Reply #32 on:
March 24, 2016, 06:59:13 PM »
I think you have done a brilliant job so far.Have a rest then a couple of little inserts to the wings to get the correct shape should return your mojo in this project!
Borsos
Reply #33 on:
March 24, 2016, 10:51:47 PM »
Hello,
and again Thank you very much!
Yes, I'll give the old wings a try and insert some plastic to make them round. Probabely I'll have to redo some ribs, but I hope it will be ok in the end.
Best wishes to you all!
Borsos
lone modeller
Reply #34 on:
March 30, 2016, 03:26:30 AM »
Oh the wing shape problem…. been there, done that…several times. I said in an earlier post that I had problems with the differences in the MF 7 - I am sure that you can salvage those wings. At least I sincerely hope that you can because this is an excellent project so far.
BigBlue
Reply #35 on:
March 30, 2016, 10:19:52 AM »
I'll second Stephen's comments. Excellent!
ALBATROS1234
Reply #36 on:
April 01, 2016, 12:37:39 PM »
i very much like your work so far.yes take a break if you need. but i do hope not very long. i really like this build.
kkarlsen
Sr. Member
'Old modeller' - Trying to catch up!
Reply #37 on:
April 07, 2016, 10:25:25 PM »
Wow, amazing build!
lcarroll
Reply #38 on:
April 07, 2016, 11:04:07 PM »
Brilliant work so far Borsos, this is real modelling you're doing! Take the break you mentioned, it's always good to get away and then a fresh start makes things look much better.
Des
Reply #39 on:
April 08, 2016, 08:09:03 AM »
Excellent work so far Borsos, looking forward to seeing more.
Pages:
3
Under Construction
Scratch builds
