Author Topic: Aviatik Berg D.II - Karaya/1:48 (39.08)  (Read 13863 times)
Offline dragonlanceHR
Re: Aviatik Berg D.II - Karaya/1:48 (39.08)
« Reply #30 on: January 19, 2016, 10:30:00 PM »
In comparison with Japo I can see now that my lighter hex should rather go just behind the pilot’s seat. I am half hex ahead of that line..well seems to be some kind of mistake with criteria taken, but I am not going to finish PhD in hex camo:)
K
That's because the Karaya kit has the cockpit 3-4 mm too far back, compared to all available drawings.
Vedran
Offline KrzysiekK
« Reply #31 on: January 25, 2016, 06:10:20 PM »
Vedran
Yes, that must be the reason.
There are slight spaces between hex colours due to improper mask implementation, but those are easy to fix
Still do not have slightest idea how to finish the top of the fuselage...but for sure I must keep symmetry at least
regards
K
« Reply #32 on: January 26, 2016, 12:06:46 AM »
Really looking great! I am sure you will work out the upper fuselage although it seems to me you already have?
« Reply #33 on: January 26, 2016, 05:37:54 AM »
Lovely!
« Reply #34 on: January 26, 2016, 11:53:48 AM »
Looking very sharp so far  :)
Offline KrzysiekK
« Reply #35 on: February 06, 2016, 02:49:35 AM »
Hi,
I just started harder part of painting- upper wings as here comes 4 colours for lighter scheme of camouflage. I have used K.u.K Luftfahrtruppe Tarnstoff 1917-1918 by Dr. Glen K. Merrill as the main source for the pattern. Unfortunately I have not prepared first base colour in right tone so had significant problems with achieving the acceptable level of work done.
regards
K
« Reply #36 on: February 07, 2016, 04:29:44 AM »
Outstanding painting K.
« Reply #37 on: February 07, 2016, 04:55:20 AM »
Excellent results to date! I admire your masking skills and the patience you have to actually do this!
« Reply #38 on: February 07, 2016, 06:15:52 AM »
Superb painting and masking skills.
Offline KrzysiekK
« Reply #39 on: February 08, 2016, 04:55:21 AM »
Hi,
Thanks but the picture above depicts fixing of unwanted colour spaces between hexs. For the first approach I use pattern consisting of 6x6 hexs, later once needed I use 1 hex pattern for corrections.
Uhhh…work is almost done
regards
K
Offline slateman
« Reply #40 on: February 09, 2016, 02:35:23 PM »
Very nicely done. Which masks did you use for the lozenge/hexagons?
Offline xmald
« Reply #41 on: February 11, 2016, 06:28:35 PM »
Splendid job Krzysiek! IT looks extremely good and I think it wasn't the easiest one to paint. Seems like one of the most aesthetically pleasing camouflages ever. those K.u.k. guys had a sense for such things; take Brumowski's camo as an example - looks like pyjamas; ))) that's  one of the reasons why the k.u.k.aircrafts are so interesting for the modelling purposes.
« Last Edit: February 11, 2016, 09:38:17 PM by xmald »
Best regards
Filip
« Reply #42 on: February 11, 2016, 09:16:10 PM »
incredible work! Awesome!
I never cared about k. u. k. airplanes. But seeing your progress I definitely have to rethink that...
Borsos
« Reply #43 on: February 12, 2016, 12:55:47 AM »
This continues to be an outstanding masking and painting job! Beautiful results!
« Reply #44 on: February 12, 2016, 06:51:09 AM »
No other word but brilliant describes what you have achieved, well done.
