Author Topic: Roden 1/72 Fokker D.VII (OAW) and Albatros D.Va -> Jasta Raben  (Read 20304 times)
Offline jeroen_R90S
Re: Roden 1/72 Fokker D.VII (OAW) and Albatros D.Va -> Jasta Raben
« Reply #120 on: March 12, 2017, 12:13:11 AM »
A  bit more progress, most of the rigging is on and the D.VII had it's wheels added. I used Ushi Fine (the Super Fine is too thin for my taste) and it looks pretty much like my usual 0,06 and 0,08mm fishing line.The Ushi wire takes some getting used to, they tend to stick together (static charge?) and the ends curl up when you add a bit of CA glue. So it took much longer than usual, but in some cases it's a lot easer to use than the normal fishing wire -such as the axle ring rigging of the Fokker and the control cables from wing to fuselage. I'll probably use this on my next 1/72 model. It does not add strength, but these models don't really need that anyway.
The Albatros had a broken aileron control horn fixed and still needs the aileron controle wires added, the elevator rigging is still unattached on one end. I also worked on the propellers and found some usable propeller logo's on an Americal Jasta 4 decal sheet I bought from Andreas (Borsos) last year.
Turned out it also had the right crosses for the Fokker on it instead of those that are now on it, as the Roden ones were unusable... Too late to fix that now.
Finally some daylight time to take better pictures, too:
Probably the next update will see the Fokker completed, and the Albatros should (hopefully) follow soon after that, too! :)
Jeroen
« Reply #121 on: March 12, 2017, 01:10:49 AM »
Coming along beautifully, especially at this scale.
« Reply #122 on: March 12, 2017, 05:41:11 AM »
A pair of beautiful and very colourful models.
Offline jeroen_R90S
« Reply #123 on: March 15, 2017, 08:46:26 PM »
Thank you Juan and Stephen!
Hopefully there's some uninterrupted modeling time in there to finish them up! :)
Online Borsos
« Reply #124 on: March 15, 2017, 11:57:08 PM »
Really nicely built, colorful and sweet!
Borsos
« Reply #125 on: March 16, 2017, 09:16:43 AM »
They're both looking great, I'm looking forward to seeing them both finished!
« Reply #126 on: March 16, 2017, 09:31:10 AM »
Both a coming along wonderfully so far , like the Fokker scheme it looks really sharp .
Online lcarroll
« Reply #127 on: March 16, 2017, 11:19:57 AM »
Jeroen,
    Very impressive work, especially in such a small scale. Great colour schemes, very skilled detailing and impressive attention to detail; what more can I say at this point?! Looking forward to the finished products presentation!
Offline jeroen_R90S
« Reply #128 on: March 17, 2017, 04:36:28 PM »
Thanks for the support, Borsos, Ian, Terri and Lance! Today is a day off for me due to all those extra hours working, so hopefully some good progress! :)
« Reply #129 on: March 17, 2017, 04:39:33 PM »
Beautiful birds, Jeroen. Superb.
Offline jeroen_R90S
« Reply #130 on: March 18, 2017, 01:38:34 AM »
Thank you, Manni!
Fokker is done, save for all the paint that's still damp and some glue that's still setting at this stage.
Final bits included the Oigee sight, anemometer, lift handles, boarding step and flare gun. I'm now just about cross-eyed, but glad this one is done.
A quick shot with my phone camera, better pictures with neutral background when all is secured:
The Albatros had it's rigging completed and the dabs of thick paint I use to fill the holes are now drying, too.
Jeroen
Online RAGIII
« Reply #131 on: March 18, 2017, 06:05:04 AM »
The DVII has really turned out well! I am looking forward to seeing the Albatros soon!
« Reply #132 on: March 19, 2017, 02:35:40 AM »
Lovely work Jeroen! They look clean, neat and very beautiful! I love the schemes you used. Regards, Marc
Offline jeroen_R90S
« Reply #133 on: March 25, 2017, 06:31:56 AM »
Thanks, RAGIII and Marc! :)
I'm currently working on the Albatros, rigging and control wires completed (save for the X wires for the undercarriage), holes filled with thick paint and polished flush, lower wing crosses still wet and currently drying awaiting a local flat coat... should hopefully all be completed by next weekend. Parts bag gets precariously empty by now!
Jeroen
Offline jeroen_R90S
« Reply #134 on: September 27, 2017, 10:22:59 PM »
Finished, finally! :) :) Thanks for the help and support here! :)
More pictures here:
http://forum.ww1aircraftmodels.com/index.php?topic=8916.0
Now to go and read all the stuff I've missed here during summer...!
Jeroen
