Author Topic: Another Macchi!  (Read 10762 times)
Offline ermeio
Re: Another Macchi!
« Reply #15 on: July 29, 2015, 04:31:19 AM »
Hi All
I would like to throw the following up for discussion. I would like to suggest that both of the color schemes are incorrect as identified by HPH. After spending some time with the Windsock Datafile, I think that the upper hull both in front of and immediately behind the pilot should be unfinished aluminum for M 7288 and dark green, matching the rest of the upper surfaces, for M 13083. Unless I miss read the information in the Datafile, M 13083 is most likely wrong, as HPH show these areas as natural wood and, best I can tell, they were in fact aluminum.
Thanks for looking and everyone keep up the good work.
I agree, Dave,
But without considering this position ad definitive.
M 13083  upper surfaces probably are green, but dark stained wood is an alternative.
It would be nice to see the original photo since usuallly the wood veneer is discernible in the glass negatives.
Another possibilità is the existence of old profiles coloured with pencils like we have for the Caproni - an entire album with all the markings.
As for the other macchi, I cannot esclude white or very light cream for the upper part of the nose.
In these macchis alluminium is painted, not a tole. See the Caproni Ca 20.
Re: Another Macchi!
« Reply #16 on: July 29, 2015, 04:55:33 AM »
Very wonderful painting, Dave.
Re: Another Macchi!
« Reply #17 on: July 29, 2015, 05:12:15 AM »
Await further photos.....
Re: Another Macchi!
« Reply #18 on: July 30, 2015, 08:11:54 AM »
Outstanding work on the Hull! Your wood effect is excellent! As for the colors you are discussing I don't have any reference but the possibilities seem reasonable to me.
Re: Another Macchi!
« Reply #19 on: July 30, 2015, 08:40:31 AM »
I couldn't agree more, Dave!  Brilliant!
Offline 15badcats
Re: Another Macchi!
« Reply #20 on: July 30, 2015, 10:16:49 AM »
Dave did you have the same problems Des did with the cockpit?
Re: Another Macchi!
« Reply #21 on: July 30, 2015, 10:39:26 AM »
Beautiful job with the wood Dave and your aluminium finish is excellent. Be wary of the decals, they are very translucent.
Offline mammut08
Re: Another Macchi!
« Reply #22 on: July 31, 2015, 01:30:16 AM »
Hi All,
Thank you for the kind words. Ermeio, interesting thoughts on the colors. The Windsock datafile also has a photo of one airframe that displays a camouflage pattern on the upper hull nose. I would love to see a photo of the rest of that aircraft.
15badcats, yes, I had the same issues with the cockpit as Des. It all fits, but very tightly. Moreover, the floor cross-members are undersized and do not touch the hull on either side of the airframe. Overall, I have seen the same issues as Des. My hull also has a warp at the tail end that throws the entire tail out of alignment. I think the make or break part of the build will be attaching the upper wing. We will see, we will see...
Des, thanks for the heads up on the decals. I had been contemplating making masks and your observation on decal quality made up my mind for me. In fact, all of my markings will be home made. This will be my first attempt at making my own multicolor masks. I am doing so with my Silhouette Portrait craft cutter. Here is a link: http://www.amazon.com/Silhouette-SILHOUETTE-PORTRAIT-Portrait/dp/B009GZUPFA . Everyone should have one of these. They cost about the same as a mid-range airbrush and have tons of cool applications.
That's what I have today.
Best,
« Last Edit: July 31, 2015, 02:27:41 AM by mammut08 »
Offline mammut08
Re: Another Macchi!
« Reply #23 on: August 04, 2015, 01:03:10 AM »
Hi All,
A quick update on my build. My Macchi's hull in complete with the exception of the stabilizer supports and wires. All markings are home made with my stencil cutter. This was my first attempt at multicolored roundels and these are not perfect - a touch out of round and next time I will spray the outside edge with green, then white, red and green to eliminate the white paint showing around the outside edge. Otherwise, a little light weathering to the lower hull using very thinned Tamiya deck tan sprayed along the lower edges. These also received a few paint chips here and there. Finally, the entire hull was given a burnt umber filter to tie everything together.
Thanks for looking,
Re: Another Macchi!
« Reply #24 on: August 04, 2015, 04:29:46 AM »
Very superb painting, Dave.
Re: Another Macchi!
« Reply #25 on: August 04, 2015, 04:52:05 AM »
  Dave,
Outstanding update my friend. Love those cut stencil marking too. Keep up the great progress.
Re: Another Macchi!
« Reply #26 on: August 04, 2015, 07:45:18 AM »
Great job with the markings Dave and your paint work is excellent.
Re: Another Macchi!
« Reply #27 on: August 04, 2015, 08:13:33 AM »
Outstanding painting and weathering! Your painted markings look great to me!
Re: Another Macchi!
« Reply #28 on: August 04, 2015, 08:22:16 AM »
    Excellent paint work Dave, the wood work is particularly impressive and I think your masked markings are beautifully done. Another really pretty Macchi, both you and Des are doing wonders with these little devils!
Re: Another Macchi!
« Reply #29 on: August 04, 2015, 10:41:09 AM »
beautiful!
