Author Topic: Finished: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)  (Read 52466 times)
Offline huberlu
Re: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)
« Reply #30 on: July 11, 2015, 05:35:22 PM »
Hello,
I read somewhere that the Hotchkiss 1909 was lighter and generally more used than the Hotchkiss 1914, which was too heavy.
So I took the opportunity to buy both machine gun!!! The 1909 is equally beautiful!
I will choose which used later.
I will make a mold for a pair of cylinder.
Offline huberlu
« Reply #31 on: July 16, 2015, 08:51:45 AM »
- The seat is finished.
    evergreen 2.4mm  tube.
    Evergreen 1mm:
    The breech:
« Reply #32 on: July 16, 2015, 08:59:23 AM »
Great work.
« Reply #33 on: July 17, 2015, 06:15:54 AM »
nice update louis,i lways enjoy your builds. i saw somewhere that the 1914 hotchkiss was used alot by ground troops on a tripod. it must have been used on some aircraft or else why did gaspatch make one. i did not research this before but i wonder which aircraft used it. have  lot of books and datafiles i must have a look.
Offline huberlu
« Reply #34 on: August 18, 2015, 07:11:22 AM »
Thank you!
The biggest parts of the gun ready to be glued...
The two parts glued together ... of course the wrong place.
The good one and XF18 Tamiya:
The handle of the gun and the trigger.
The groove is engraved with small tool shaped screwdriver.
Regards.
« Reply #35 on: August 18, 2015, 07:19:58 AM »
Excellent work on the 'cannon' Louis, that will look fantastic mounted on the aircraft.
« Last Edit: August 20, 2015, 08:14:17 AM by Des »
« Reply #36 on: August 18, 2015, 09:43:34 AM »
Outstanding gun, Louis.
Offline pietro
  • What?! Are you kidding?!
« Reply #37 on: August 19, 2015, 03:40:50 PM »
Louis, that is incredible! I wish I could do half as good in 1/32. You are a true master craftsman..
Pietro
« Reply #38 on: August 19, 2015, 10:51:05 PM »
Beautiful work on the Cannon! This is really outstanding work!
Offline huberlu
« Reply #39 on: August 21, 2015, 08:45:52 AM »
Thank you very much!
that's all there ... except for the sight too fragile, the cable from the trigger and a bit of paint retouching.
« Reply #40 on: August 21, 2015, 09:26:50 AM »
 Louis,
That's one beautiful QL Cannon my old friend. Looking forward to seeing this project completed. No doubt she'll be a real show stopper. Well Done my old friend.
« Reply #41 on: August 21, 2015, 12:40:13 PM »
excellent!
« Reply #42 on: August 21, 2015, 12:46:40 PM »
You have done a superb job with the cannon Louis.
« Reply #43 on: August 21, 2015, 01:25:18 PM »
fantastic work louis.
« Reply #44 on: August 22, 2015, 03:00:29 AM »
Simply gorgeous, Louis!  That gun, in itself, was quite the project.
« Last Edit: August 22, 2015, 07:50:02 AM by coyotemagic »
