Author Topic: Finished: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)  (Read 52470 times)
Re: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)
« Reply #15 on: June 21, 2015, 10:44:05 PM »
Your detailing is great.
« Reply #16 on: June 22, 2015, 07:20:10 AM »
Excellent, keep going !
Offline jamieg
« Reply #17 on: June 22, 2015, 01:09:08 PM »
I have one of these kits. I was planning to simply do it per the box, but your efforts have me reconsidering. very interesting build.
Jamie
« Reply #18 on: June 22, 2015, 01:58:50 PM »
Superb detail work as always, Louis!  So glad you found your way over here.
« Reply #19 on: June 28, 2015, 11:43:52 AM »
excellent work louis, much respect to you.
« Reply #20 on: June 29, 2015, 12:03:05 AM »
Superb detailing Louis, a pleasure to watch!
Offline huberlu
« Reply #21 on: June 29, 2015, 04:02:48 AM »
Thank you!
Some pictures showing the airplane Voisin Ca2 before restoration ( Musée de l'Air et de l'Espace / Memorial Flight).
The aircraft had been modified to fly without the pilot.
1923-1924
And drawings ....
http://www.techno-science.net/?onglet=news&news=3957
"Le monde illustré avril 1923"
« Last Edit: July 12, 2015, 06:02:10 AM by huberlu »
Offline xmald
« Reply #22 on: June 29, 2015, 06:38:42 PM »
Your progress looks great! Also the plane itself is much interesting. I`m going to follow your build... Keep up the good work!
Best regards
Filip
Michael Scarborough
« Reply #23 on: June 29, 2015, 11:13:33 PM »
This is clearly a build that will be worth following up until the end. Great start.
Avant!
Cheers from NYC,
Michael
« Reply #24 on: June 30, 2015, 08:13:46 AM »
this is a great example of taking a substandard kit and making a masterpiece from it. louis is the man to do it. i have seen and respected his models for many years.
Offline huberlu
« Reply #25 on: July 10, 2015, 04:43:46 AM »
Thank you very much!!!!
Well...
The windshield is not beautiful, it is full of bubbles and not transparent at all. Its central part is too short and I think I'll have to cut it to enlarge a little.
In addition I split ... misery.
In front of the windscreen there are two components that can (for real) open and which are partly transparent. So I just removed to replace with a piece of transparent plastic. It's a little too flat now ... I'll stick can be above the two components to put a little thick.
I made a fire extinguisher to put next to the cannon (shot plastic).
The engine does not please me. It's a shame it's all there but everything is crooked.
I bought a machine gun Hotchkiss M 1914 models directly from GasPatch, delivered in 4 days. I let you judge the pictures the quality of their work:
http://www.gaspatchmodels.com/accessories/
Regards.
« Reply #26 on: July 10, 2015, 08:55:49 AM »
Nice to see more progress on this kit but it is a real disappointment to run into so many issues with the kit, the engine looks as though it will need an enormous amount of work or a complete rebuild. I will be following along to see how you overcome these problems. On a brighter note, the machine gun looks brilliant as does the fire extinguisher.
Offline huberlu
« Reply #27 on: July 11, 2015, 01:17:14 AM »
Thank you.
I need a plan ( length width height etc) to built the  engine (renault 12fe). If you have one...
Regards.
« Reply #28 on: July 11, 2015, 01:34:50 AM »
The cockpit tub and added details are looking fantastic! Too bad about the engine! I am sure you will sort things out!
« Reply #29 on: July 11, 2015, 02:29:28 PM »
nice progress louis, i didnt realize they used the heavy hotchkiss on the voisin aircraft. i wondered which ones use this gun, i mostly used to see the 1909 on french fighter planes. voisin has a big wingspan.
as far as the engine maybe you have to make a cylinder like you did for the freidrichshafen ff33e by techmod.
