Author Topic: Base for Seaplanes  (Read 5349 times)
Offline malaula
Base for Seaplanes
« on: June 01, 2015, 10:17:05 PM »
[/URL]
This is a small diorama base I did for my Gotha WD7.I thought it might be of interest to show my way to achieve a quite realistic looking beach scene.
Ground work made with a mix of sand and white glue,over a styrofoam board .Jetsam is kitchen herbs,tobacco and modelrailroad scatter for the seaweed and algae.Painted with acrylics.
A sheet of clear plastic is cut to fit the bank and attached with clear acrylic caulk.
Thick acrylic gloss varnish tinted with a very small amount of green-grey ,applied thickly and left to dry.
When the clear coat has dried thoroughly(most important!) acrylic transparent caulk is applied and sculpted with a wet finger  or adequate tool.
Again,the base is put aside to dry,in this case it took about a week .
When the caulk has turned completely clear ,gloss varnish is applied generously and the waves are picked out with a small brush and gloss white. Details of the jetsam are painted with several greens and browns .
Offline Squiffy
Re: Base for Seaplanes
« Reply #1 on: June 01, 2015, 11:15:41 PM »
You are the master of dioramas! I really must improve on my own efforts.
Offline Mark
« Reply #2 on: June 02, 2015, 03:56:27 AM »
OUTSTANDING!!!
Mark G
Offline Verbeek
« Reply #3 on: June 02, 2015, 04:02:18 AM »
Great! Looks very good.
Out of all the things I have lost, I miss my mind the most.
« Reply #4 on: June 02, 2015, 05:17:29 AM »
Wow!!! ;D
« Reply #5 on: June 02, 2015, 07:23:03 AM »
Extraordinary looking base, Matz!
« Reply #6 on: June 02, 2015, 07:50:52 AM »
What you have created here looks fantastic, it looks very realistic.
« Reply #7 on: June 02, 2015, 08:03:21 PM »
Brilliant efforts! Very realistic. :D
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #8 on: June 02, 2015, 08:54:06 PM »
Fantastic, maybe Des can pin it at the "Hints and Tips/Questions about modeling"?
Is it possible to post a pictures of the materials used for recreating water? I read them in your post, but having a visual about them will be better!
best regards,
Sasho
Think globally, act locally!
Offline malaula
« Reply #9 on: June 02, 2015, 11:43:12 PM »
Hi all,thanks a lot for your nice comments! Squiffy,I started exactly like you with a grass mat on the dining room table and hangar tents made of glue-drenched tissue ...that's about 15 years ago now and I'm still learning a lot with every new project I start.
I think your dioramas are pecfect as  displays for your nice models because you can rearrange everything for new sceneries.
Sasho,I used a 1mm thick plastic sheet,Revell aqua color gloss clear,and Acrylic thick material you get in every do-it-yourself market for small money.Don't use silicone, paint won't stick to it.You can see it on the top of the third photo.You could even use genuine Acrylic gloss varnish instead of revell aqua color if you want to do a larger dio ,savesw you lots of money.
Most important is to let each layer dry thoroughly until it 's clear,if it is still milky and you apply another layer it will stay like this forever.
You could also quit with the clear plastic sheet ,if you want bigger waves,and apply the acrylics to a sculpted and painted styrofoam board ,like I did here:
One hint to the colour of water:Do not paint it blue!
« Reply #10 on: June 03, 2015, 03:14:46 AM »
Great stuff Malaula. FWIW there was a recent issue of The Weathering Magazine devoted to water, with several interesting techniques demo'ed for creating realistic water...
Offline Oeli
« Reply #11 on: August 17, 2015, 03:37:30 AM »
Yes, Great work! :o
Hope my dioramas someday looking like yours
Kindly regards
Jörg
« Reply #12 on: August 17, 2015, 06:03:04 AM »
Thanks for this Malaula, I'm definitely going to attempt a water base for one, if not both, of my WNW HB's soon, this will help a lot! Nice work, the colours are very realistic, as is the sculpting of the waves and ripples.
Offline FarEast
« Reply #13 on: August 17, 2015, 06:28:25 AM »
My God!
That is incredible!
Offline Malteser
« Reply #14 on: August 28, 2015, 03:39:07 PM »
Wow, your work is stunning, thanks for sharing.
Suzanne
