Author Topic: Nieuport 24C-1 Der Kampfflieger in 1/100  (Read 2263 times)
Offline gomidefilho
« on: February 12, 2015, 01:26:11 AM »
One more model of Der kampfflieger range, in this case is a 1/100 Nieuport 24C1 in colors of the ace Willian Herrison (11 victories)...
Re: Nieuport 24C-1 Der Kampfflieger in 1/100
« Reply #1 on: February 12, 2015, 07:38:14 AM »
Another very nice looking model Péricles, what is the main reason that you build your models in 1:100 scale?
Offline gomidefilho
« Reply #2 on: February 13, 2015, 05:39:02 AM »
Thank's.
Many reasons, but the mainly is a lack of space for storage the finished models, the second is a search for scale between 1/144 and 1/72, 1/100 is easy for made scratchs too, since 1 meter equal 1cm. The challenge and surprise of small is very pleaseant too. ;)
Offline Pgtaylorart
« Reply #3 on: February 13, 2015, 06:05:09 AM »
That's one great advantage to paper models. You can build them in any scale you wish, within reason. It's usually better to scale a model down than to up-res it, unless it's all in a vector format. Bit map textures will blur if you scale up.
Also, for some reason, common scales in paper are different than in plastic. Plastic will do 1/32, 1/48, and 1/72, while paper will do 1/33, 1/50, 1/60, and 1/100. But of course, as I said, paper can change to any scale with just a quick setting change on your printer.
Offline croas
« Reply #4 on: February 13, 2015, 11:28:34 AM »
Pericles,
great model !
What did you use for rigging ?
Offline gomidefilho
« Reply #5 on: February 22, 2015, 09:30:37 AM »
Thank's! I use cirurgical wire for rigging...
