Author Topic: Spin Models Caproni Ca.20  (Read 8926 times)
Offline ermeio
Re: Spin Models Caproni Ca.20
« Reply #15 on: January 27, 2015, 07:05:56 AM »
Remarkable job, jessie.
I scratchbuilt the Ca 20  in 1/48 when the Spin model was still many years away.
Therefore I have a soft spot for this aircraft (my avatar :-) )
er me
« Reply #16 on: January 27, 2015, 10:12:46 PM »
Very nice work and paint.
Offline jessie_c
« Reply #17 on: February 11, 2015, 03:55:39 PM »
I've solved the wing spar problem with a couple of sections of aluminium tubing and some chopped-off pins. The wings get the pins
While the fuselage gets the tubes
There's evidence of recent filling visible
This lower kingpost had more air bubble than pulley, so I sanded the offending ones off and replaced them with punched styrene discs. Of course, after having done that, I realised that it ought to have gone where I glued the other one and that one ought to be farther forward. Oops. Time for a little debonder or some judicious prying...
If you squint, and pretend really hard, you just might convince yourself that there's an airplane somewhere in this picture
"When once you have tasted flight you will walk the Earth with your eyes turned skyward
for there you have been and there you will always long to return."  Leonardo Da Vinci
« Reply #18 on: February 13, 2015, 04:40:13 AM »
Looks as though you are making great progress Jessie. I see the Airplane emerging  ;)
« Reply #19 on: February 13, 2015, 07:39:46 AM »
Starting to look like an aeroplane now Jessie, the wing pins and  fuselage tubes will make for a very positive connection.
Offline jessie_c
« Reply #20 on: February 15, 2015, 04:42:44 PM »
Most of the preliminary work is done. I'll need to paint the undercarriage legs and other bits semi-gloss black and that will be the last of the painting to be done. Then assembly and rigging. Here's the fuselage as it strands
And a look underneath
Hanging together by friction isn't really a good idea
But it's definitely looking much more like an airplane now
The rigging on this one will be structural. Otherwise as can be seen, it'll sag.
« Reply #21 on: February 15, 2015, 11:13:32 PM »
Looking fantastic, Jessie!  She's gonna be a beauty.
Offline jamieg
« Reply #22 on: February 16, 2015, 08:15:26 AM »
That is shaping up very well.
« Last Edit: February 16, 2015, 11:33:13 PM by jamieg »
« Reply #23 on: February 16, 2015, 02:07:59 PM »
Looks awesome Jessie! Looking forward to the next steps.
« Reply #24 on: February 16, 2015, 02:48:49 PM »
You are making excellent progress with this model Jessie, quite an attractive looking aeroplane.
« Reply #25 on: February 19, 2015, 02:39:36 AM »
Exellent work.
Offline jessie_c
« Reply #26 on: February 23, 2015, 10:25:26 AM »
I spent much of the last week thinking through the rigging and how I was planning to get it attached. I finally decided to attach two of my twisted wire loops to the upper kingpost. Since taking these pictures, I've painted all the struttery semi-gloss black, but watching paint dry is boring so I haven't got any pictures of that.
Offline jessie_c
« Reply #27 on: February 23, 2015, 02:11:22 PM »
Now the black is dry, and I've got the very first bits of rigging done, on the landing gear legs
Looking closely at pictures of the spinner reveals that there aren't huge gaping square holes for the propeller to fit through. There are very close fitting covers instead, so I have to fill the gaping holes. First step is some gap filling superlue
« Reply #28 on: February 23, 2015, 08:18:01 PM »
This is such an interesting build to follow. Thanks for sharing it with us, Jessie.
« Reply #29 on: February 26, 2015, 11:49:48 PM »
Very beautiful work Jessie.
