Author Topic: Copper State Brandenburg W 12  (Read 26624 times)
Offline Wolf
Re: Copper State Brandenburg W 12
« Reply #15 on: October 29, 2014, 10:25:04 PM »
Very interesting log. It seems this is a very nice kit.
« Reply #16 on: October 30, 2014, 01:21:52 AM »
Stefan I will see at it, thank you
Wolf yes it is, but there are mistakes on it and the Instruktion is not so good as from Karaya. But there are scale plans on it.
« Reply #17 on: October 30, 2014, 04:33:50 PM »
i look forward to see you build this one martin. this is the new csm release right? i have the original kit, i bought used and some damage had been done to it. i was hoping when they did the restoration and upgrade to the masters they would have noticed this is the wrong engine and put the right one but alas we arent so lucky. its still a nice kit and the only other 1/48 w.12 is vacuform from sierra scale. good luck i will watch this one.
« Reply #18 on: October 30, 2014, 07:48:36 PM »
You're moving along quite nicely with this one Martin, the thining of the fuselage is looking good.
« Reply #19 on: October 31, 2014, 12:03:40 AM »
Thank you for your comments Scott and Des.
Scott it is the old one.but a nice kit.
Stefan the floats are ok.
« Reply #20 on: October 31, 2014, 06:24:49 AM »
The cockpit further drilled and sanded.
Made dashboard, rear wall, curtain wall made ​​of plywood. Customized tank and adjusts front seat.
Plywood floor and central wall means used for testing purposes.
« Reply #21 on: October 31, 2014, 06:43:48 AM »
Beautiful work, Martin!  Here's a little something for you to look at for inspiration.  I'll try to find his build log for you.
http://amug.org/~copperst/gallery/lance-w12/index.html
« Reply #22 on: October 31, 2014, 07:07:41 AM »
Thank you Bud.
I have his photos, but I had found another side.
Here she is : http://www.neptune-association.nl/
about building a real Netherland W 12.
« Reply #23 on: November 02, 2014, 06:47:49 AM »
After a lot of work one hardly sees something. Here a few pictures.  :-[
In the engine the oil pan changed.
Dividing walls in engine space inserted.
Frames for rear seat soldered and both cross-beams in addition made.
Leader's space ground, dividing wall and front raised ground stuck.
Rear lower side parts made. All wooden parts with varnish provide and side walls painted.
Tax linkage for steering system started.
« Reply #24 on: November 02, 2014, 07:46:59 AM »
You are cruising along quite nicely Martin, all the little extras make a lot of sense but even if they can't be seen they are there for a purpose.
« Reply #25 on: November 02, 2014, 07:56:19 AM »
Thank you Des.
But some parts will be see inside the plane.
And I have the photos. ;D
« Reply #26 on: November 03, 2014, 06:39:02 AM »
End at the front body end stuck on and struts inside at the side right.
Tank with seat and belts finished.
Rear seat and belts finished.
Steering system and pedals finished.
Offline Rob Hart
« Reply #27 on: November 03, 2014, 08:35:20 AM »
Nice work. I'll use your photos as reference when I build mine.
« Reply #28 on: November 03, 2014, 08:55:21 AM »
Thank you Rob.
Martin 8)
« Reply #29 on: November 03, 2014, 10:38:12 AM »
Martin,
This is looking great! Your additions are making a terrific difference!
