Author Topic: Ansaldo Baililla A.1 1/32 Scratch.  (Read 19069 times)
Offline Ronkootje
« on: May 23, 2014, 07:01:51 PM »
Hi guys,
New project when i have the time between castings.
Here started on the wings using 3mm styreen sheet sanding and scraping it in shape.
Made a start on the fuselage.
The engine working on of and on long prgress but getting there.
Regards Ron
« Last Edit: August 06, 2014, 09:49:18 AM by Ronkootje »
Offline Ssasho0
    • Scale Models Club Bulgaria
Re: Contest Entry Ansaldo Baililla A.1 1/32 Scratch.
« Reply #1 on: May 23, 2014, 07:30:51 PM »
wondefull wonderfull wonderfull! I will be watching this with pop corn and beer from the first row :) Recently I found your Gotha GV conversion that had an unfortunate ending and I was amazed by the skill, effort and techniques you put into the build, so I expect no less from this one, BUT with happy ending this time :)
Best regards and keep up the good work,
Sasho
Think globally, act locally!
Offline Beto
« Reply #2 on: May 23, 2014, 09:26:35 PM »
Splendid as always!!! Did you make your own photoetched base plates for the engine cylinders?
Online RAGIII
« Reply #3 on: May 23, 2014, 09:38:00 PM »
Ron,
Outstanding work on the engine and wing! Your Talents are as amazing as all of the others who post in this section. I am looking forward to your progress!!
« Reply #4 on: May 23, 2014, 11:31:07 PM »
Awesome work Ron!
« Reply #5 on: May 23, 2014, 11:46:33 PM »
Exellent work Ron.
« Reply #6 on: May 24, 2014, 02:38:52 AM »
Brilliant work, as usual, Ron!  Really looking forward to this one.
« Reply #7 on: May 24, 2014, 03:39:00 AM »
Absolutely fantastic work. The engine is a little marvel - no wonder it has taken a while to build it! Do keep us posted on future progress.
« Reply #8 on: May 24, 2014, 09:00:24 PM »
Oh Ron!  I'm swooning over this one.  Big fan of the Ansaldo.  You'll do it proud , no doubt.  Looking forward to following this one. :D
« Reply #9 on: May 24, 2014, 10:54:57 PM »
   This is real modelling, Ron, and it's coming along in spectacular fashion! Keep those updates flowing, much potential for learning here. 8)
Offline IFF1418
« Reply #10 on: May 25, 2014, 01:30:42 AM »
Hello Ron,
Fantastic work on the engine. A new world is opening for me! As Rick said : all the people who post in this section are so talented.
Kind regards
Patrick
Offline Piotr D.
« Reply #11 on: May 25, 2014, 06:23:06 AM »
Hi Ron!
I'm also planning to build Balilla in similar scale (1/33) but using veneer and japanese paper (or maybe canvas) so I'll be watching Your work. Engine looks great! What paint scheme are You planning for Your Balilla?
___________
Best regards
Piotr
Offline Ronkootje
« Reply #12 on: June 01, 2014, 10:04:07 PM »
Yes i drew them up myself and then send the to be etched.
Offline Ronkootje
« Reply #13 on: June 01, 2014, 10:05:14 PM »
Hi Ron!
ATM i dont know what paint sceme i will use first build it :)
Ron
Offline Ronkootje
Re: Ansaldo Baililla A.1 1/32 Scratch.
« Reply #14 on: August 25, 2014, 03:49:50 AM »
Finaly can post some progress the engine is almost finished just a few more parts to be made:
Fuselage is redone 3 times until i was happy, hard to make this one but its spot on according to the factory drawings i got from italy.
If you conpare them to the data file drawings they are different then the factory ones so beware using them in scratch build projects.
Here i started to make a mold for resin top using styrene plastic, it has to be right the first time since the mold cant be used again.
here is the mold complete and filed with resin and placed in a pressure chamber to get the air bubbles out.
Here is the finished block of resin witch will be shaped accordingly lots of sanding and scraping so respirator on since resin is not good for the lungs
Here drawn a template on the comp and glued it with contackt glue on the resin block then shaped the top and sanded smooth.
Getting there next up tail wings.
Regards Ron
