Author Topic: Pyro Bleriot XI  (Read 8393 times)
Offline JoeDxMB
Re: Pyro Bleriot XI
« Reply #15 on: July 20, 2013, 06:39:30 AM »
Thanks  guys  :)
BTW Zabu,  I won that MS type L kit
No one else bid on it and it was a great price.
It  will be my next build..... another WWI aircraft ..... finally. :)
« Last Edit: July 20, 2013, 08:16:14 AM by JoeDxMB »
Offline JoeDxMB
Re: Pyro Bleriot XI
« Reply #16 on: July 26, 2013, 03:24:15 AM »
It's finally completed!  :)
No, it's not perfect but, I'm happy with it considering the low detail  of the old kit.
Now, on to my Morane Saulnier type L.  :)
« Last Edit: July 26, 2013, 05:27:56 AM by JoeDxMB »
Offline Zabu
Re: Pyro Bleriot XI
« Reply #17 on: July 26, 2013, 06:37:46 AM »
Hi Joe.
Your Bleriot it's a very beautiful sight. Your right in being happy!
I'm glad that you won the MS. Hope to see more from it.
Offline JoeDxMB
Re: Pyro Bleriot XI
« Reply #18 on: July 26, 2013, 07:13:31 AM »
Thanks.  :)
I have  to decide what version  of the MS-L that i want to buld as it has PE parts for about 3  versions.
It has  more PE parts than plastic parts and I  first have to decipher the instructions.
Anyway, it will no be a quick build  but,  once I get stared it will hopefully go relativly easy if not quick.
I may take a break from it on occasion (to regain or keep my sanity) by working  on a J-3 Cub that  I have.   ;)
« Last Edit: July 26, 2013, 07:15:25 AM by JoeDxMB »
Re: Pyro Bleriot XI
« Reply #19 on: July 26, 2013, 07:56:55 AM »
She's absolutely gorgeous, Joe.  You did a brilliant job on the rigging.
Re: Pyro Bleriot XI
« Reply #20 on: July 26, 2013, 08:28:02 AM »
Congratulation Joe on completing this model, you have done a beautiful job with superb results, the rigging is excellent, very well done and I look forward to seeing your MS.
Re: Pyro Bleriot XI
« Reply #21 on: July 26, 2013, 12:36:55 PM »
Well done on the Bleriot, Joe. Superb job.
Offline Whiteknuckles
Re: Pyro Bleriot XI
« Reply #22 on: July 26, 2013, 02:49:34 PM »
Nicely turned out Joe, great job.
Looking forward to your MS-L ;)
Eternal Apprentice
Offline Ssasho0
    • Scale Models Club Bulgaria
Re: Pyro Bleriot XI
« Reply #23 on: July 26, 2013, 04:41:21 PM »
It really turned out great! I definately like it
Best regards,
Sasho
Think globally, act locally!
Re: Pyro Bleriot XI
« Reply #24 on: July 28, 2013, 05:09:28 AM »
  Joe,
Congratulations my old friend. Absolutely Awesome!
Offline JoeDxMB
Re: Pyro Bleriot XI
« Reply #25 on: July 28, 2013, 05:51:59 AM »
Thank you all. :)
Offline Rob Hart
Re: Pyro Bleriot XI
« Reply #26 on: August 06, 2013, 10:41:48 PM »
Joe,
I completely missed this one. Excellent work on the rigging. You are a wiz with these pre war crates. How similar to the clipped wing  'Penguin' trainers was this aircraft?
Offline JoeDxMB
Re: Pyro Bleriot XI
« Reply #27 on: August 07, 2013, 01:56:25 PM »
Thanks Rob.
BTW, the simulated turnbuckles are just tubes I got from "Bob".
Then, darkened a bit with a little Tamiya weathering  powder.
I do not know too much about the "Penguin" but they do look similar.
« Last Edit: August 09, 2013, 03:13:27 AM by JoeDxMB »
Re: Pyro Bleriot XI
« Reply #28 on: August 11, 2013, 04:57:02 AM »
Excellent modelling and rigging. Interesting to see someone else use metal for the wires especially on one of these very early machines which are not easy to use thread on.
I am not an authority on French machines (or British either) but the Penguin had a 35hp Anzani engine and a shorter span wing: 18 feet 6 inches whereas the XI was 31 feet 9 inches. They were used as trainers at Avord, France where the "Bleriot School" of training was used. The student pilots gained experience by taxiing and racing back and forth at between 30 - 40 mph along the grass field to allow them to get a feel for longitudinal and lateral stability. When the instructor was happy with the student he was allowed to get into a full sized machine and repeated the Penguin lesson. Only when the instructor gave the command did the student pilot actually take off and then he had to hold the machine a few feet above the ground and fly in a straight line. When this skill was mastered the student was allowed to fly a little higher and for a little longer until he was ready to complete a three leg cross country flight of 225 km per leg, stopping at the end of each leg to refuel and collect a signature. This was an advanced system at a time when student pilots in other schools would stand on the ground while another student would fly around the airfield with the instructor on the ground shouting instructions as the aeroplane passed over!  The other student pilots on the ground were supposed to listen to the instructor too!!
   Although the Bleriot school had many accidents they had few casualties because the speeds were low and the steps were gradual and a handful of instructors could train a large number of pilots. This system was in use in 1914 and it could take up to five months to fully train a pilot. Later this time was reduced. It should be remembered that the RFC lost more pilots killed in training than in combat: when two-seat trainers were not available the Bleriot system proved to be relatively safe and effective.
