Just a thought on the matter and then I will shut up.....
I am also wondering about the 2nd picture like kornbeef.
If those are 4 exhausts exiting from the right side, then one might assume that there are 4 also on the left side, which
might possibly indicate V-8 type of motor.
Also, each side
seems to have 2 sets of inverted "V" struts going from the fuselage sides to the upper wing.
And, the water pipes suggest an upper wing radiator. And, the gun butts do not appear to extend into the front of the cockpit opening.
I did a very
quick flip thru "Thetford and Gray - German Aircraft of the First World War" (Yep, I know it is an old resource) and can find reference to the Benz BZ.IIIb motor, a V-8, which appeared in a few aircraft. I came across some that could possibly be candidates, but they match in as many characteristics as they do not.
But, it still might be one of those odd experimental types that Fokker was always coming up with..........
Back to sleep.....
